paulkno
- Apr 3, 2017
- Location
- Manchester
- S-Class W220 2002 320CDI
I'm looking at a W220 with soft close doors that don't work. Does anyone know what I should be looking for using the icarsoft mbii. Under PSE equipment it says no DTC's. Under the door modules it has a one for 'closing system'. Is this referring to the soft close? I have another W220 with working doors to compare with and the icarsoft has the same modules and identical actual values under the door modules.
When I got it the doors and lumbar adjust weren't working, the boot was. After pulling the fuse for the PSE pump, the lumbar began working again but still no doors. Surely if there was a leak the pump would overrun and log a DTC under PSE equipment, no?
