Omar1994
- Oct 28, 2018
- S class / 2003 / 3.7l
Hi guys, I have a Mercedes W220 (2003, 3.7l, S-class, s350)
On my way back from work. I noticed that when I put my car in drive there was a slight delay in a sense of the gear clicking in place to move off, I also noticed that when I try to put it in N or R also slight delays. Once I pulled over at a service station. I turned the engine off.. did a transmission reset. Then noticed the same problem, but this time I can’t shift gears, when I put it into manual usually on the dial it says, gear 1,2,3,4 then drive. But this time it doesn’t change, when I try to switch from comfort to sport it does nothing. The car drives normally, until I get to around 40mph and the car doesn’t want to shift gears up and you could hear a high pitch sound coming from the engine. I’ve recently put transmission fluid to see if it helps. But still the same problem.
Another problem of mine is, I’ve noticed oil in my engine coolant. Which is strange. Checking the engine oil, I still have oil in it and doesn’t seem like an head gasket problem. I haven’t seen no leaks in the enigine oil and when checking the dip stick, it shows me exactly the level of oil I have in the engine. I also keep getting warning signs on the dash, saying engine coolant level low.
Can anyone help??
Can anyone help??
