W221 back end dropped right down onto tyres
G style
Stockport
S Class 2006 320CDI
Hi all,
I require help with my s class w221 came out to find the back end on the tyres can not use car now......I have checked it with my icarsoft and its given me a code of 5286 but can not fine out what that is nor what it has do with the back end as what i have found with that code is front suspension problems .....i have checked the fuses and the relay...but not sure how to test the pump as i can not get it to run and even pressing the rise button dose nothing....I have inpluged the compressor and tryed to get a reading but im guessing that it will only read something when it reqiures the pump to activate and seeing as i can not do that i stuck at this point. Any info would be greatly appreciated.
Thanks.
Craiglxviii
Cambs UK
OK firstly what iCarsoft do you have?
It sounds as though the pump has failed and the rear valve block lock valves have stuck open.
G
G style
Stockport
S Class 2006 320CDI
Its an i980.
Craiglxviii
Cambs UK
OK so ignore the automatic diagnoses menu and go into manual. Navigate to the ABC menu and scroll down to look at system pressure. What is the reading?
G
G style
Stockport
S Class 2006 320CDI
I will go and look now mate give me a few mins.
DREAMER NO2
W124 2.6E M103 1989
Well i would get a good trolly jack and axle stands .Jack it up on the rear end jacking points, and put axle stand under the body jacking locations .So you can take the pressure off the rear suspension ,so no more damage can happen.Dont jack it up to high ,just to a normal possition..But i would say that its down on the bump stops and wont go any more ,May be its just the pump not working .
Craiglxviii
Cambs UK
There are no bump stops on ABC struts... they're called "wheelarch liners" ;)
G
G style
Stockport
S Class 2006 320CDI
Right mate sat in car now and im in diagnose mode. Into suspention and actual values then what do i do sorry for being a dum ass but im new to these readers lol.
G
G style
Stockport
S Class 2006 320CDI
Can not seem to find what you asked for mate?
Craiglxviii
Cambs UK
Are you in "Manual" mode? Do not go into "Diagnose" as the reader will just act generically. You need to choose your specific car moderl, engine type and then navigate down until you find the ABC option.
G
G style
Stockport
S Class 2006 320CDI
Right i have found a menu which states 158 left front level 10mm 161 right front level 3mm 164 rear level 127mm and 166 pressure at pressure sensor 0 bar. Does any of that help mate cause kooks to me that the pump is not working at all?
Craiglxviii
Cambs UK
No need to be sorry, I too have an i980 and a car with ABC which had exactly the same problem as you...
G
G style
Stockport
S Class 2006 320CDI
I don't have a manual mode mate i have diagnose or obd2 diagnose. If i go into diagnose i then put my details in and go though to suspension.
G
G style
Stockport
S Class 2006 320CDI
Once im in suspension i go into actual values then pressure sensor values.
Craiglxviii
Cambs UK
And the reading is... zero bar?
G
G style
Stockport
S Class 2006 320CDI
  • #18
Sorry to say it mate but im glad im not the only one.... was yours the pump that had gone?
Craiglxviii
Cambs UK
That is the manual mode I mean; most people refer to the OBD2 DIagnose as the auto diagnoses. Sorry for confusion.
G
G style
Stockport
S Class 2006 320CDI
  • #20
No promblem just thankfull of the help mate yes its at 0 bar
