Warning lights
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by peternutkins, Dec 8, 2018 at 10:50 PM.
  1. peternutkins
    peternutkins Member
    22
    Dec 1, 2018
    Your Mercedes:
    c220 cdi estate 2001
    I'm having a problem with fault warnings on my C220 Cdi w203 estate. Its telling me all the time that the 'trunk is open' which it isn't, also that the water level and screen washer fluid are low which they aren't. Is it likely that all these sensors are faulty or could there be a common cause?
    The interior light stays on if you don't turn it off which would seem to indicate that there is a problem with the tailgate.
    Any suggestions?
    Peter
Share This Page
