Water drains.
David Williams
Hi Malcolm,
Do you have anything on W208? Went out Thursday night in very heavy rain & found a steady stream running in to the passenger foot well. I can't se where it would come from under the bonet.
Many thanks,
Miles.
Just done my 208 conv - I removed the grills OK but had to use a chisel to break two clips at the back of the engine but it all went back nice and tight. The hole for the heater is huge.... once I cleared everything out I noticed that the drain had a rubber plug on the back which drained into the nearside wing and it was this plug that had gummed up. If you put your hand in behind the aircon box you will see/feel the rubber bung, just pull it off the plastic spigot and you might find that that's all you need to do.
PAPIV
hampshire uk
BLUE 1998 CLK 320 AUTO
w208 damp carpets
Hiya malcom CLK 320 has damp carpets over the last few days I wonder if you can post the plans for the drains on here ?
Or maybe email them to me , I don't know if that's the problem but at least I want to do something, thanks andy
  • #63
I can give you the details for the air intake box,,and this is the main thing for damp carpets on the passenger side
  • #65
Both sent,, go back and in edit remove your address
  • #68
You should have them,,,remove address in edit Stuart
reuben
Mercedes CLK W209 270 cdi
I get water dripping into the boot of my CLK W209 when I open it - i.e. the water runs down the boot and instead of off to the side it drips into it, which is annoying...
  • #70
That is the same as the SL open the bot and it fills up with water,,I will have to think of a mod
viffer750
Mid.Glam.
'93 190e. '74 MGB. '88 VFR750FJ
Hi Malcolm,
Could I have the ones for W201 please.
Many Thanks
Cheers
  • #72
You should have it,, you can delete your address in edit
  • #74
Alan,,I only have one so far for the water collector in front of the screen,,,you can have this,,but no one has ever asked before for this
alanuk400
Belfast NI
www.vipsec.co.uk
2018 W222 Mercedes S-Class LWB & 2006 R171 SLK 55AMG
That's ok, it should be much the same as my W220, I have been keeping an eye on that, and it has been all right so far.
I will give the W210 a good look over at the weekend.
Thanks anyway
Alan
harleyman
Co Monaghan
CL500 (W215), (450sl (R107), Porsche 965, RR Silver Shadow ll, MGB Roadster,Heritage Softail
Hi, I just joined the forum today and this is my first post as I have been reading as much as I can about R107 sl's after buying a '78 450sl last week from Chelsea Cars. May I bother you for the info on this model as I will have it up on a lift on Friday coming and would love to clean out the drains!
Many thanks in advance.
Harleyman:cool:
  • #77
Harleyman:cool:
ga§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§ail][/QUOTE]
Hello and welcome sir,,you should have it :D:D
go back and edit out your address
harleyman
Co Monaghan
Many thanks, just finished printing it out.
Is it only where 107 is shown or are most of them relevant?
Also how do I delete my email address?
  • #79
Just use the section where the 107 is in the start of the text.
go back to your post and you will see the edit button at the bottom,,click on it and you can then just wipe out the address or change any text
harleyman
Co Monaghan
Thanks again!
www.W140.co.uk&www.r129.co
