Excellent news!!
Malcolm, would you have the drains literature for a W169 A150 please? We are getting a bit misted up inside having parked on cold days....
VMT in advance!!
jc ATT. capt dot co dot uk
Sorry cannot do that one, this will normally be the heater box filter blocked, and a new filter cold fix the problem. do clean the front drains.
The SL the only way is to clip off the ears of the down plug under the nearside heater outlet pipe, the rear section has to be unscrewed, Its quite a simple job.Thanks very much for the pointer, Malcolm. We'll check it out.....
All the best
Jon
All the best
Jon
HiWith all of the rain of late,if anyone wants the clearing all the drains info on a 140-107-123-124-126-201.
Checking them now stops so much damage on the heater motor and other area's.
Please ask for the info.
Hi Malcolm,
Could you please send over your drain cleaning papers for a W124/S124 estate (I have an '89 200TE) - water dripping in the sunroof so need to clean them all out...
Many thanks, Jon
Malcolm passed away in August
http://forums.mercedesclub.org.uk/index.php?threads/malcolm-end-of-an-era.163442/
I've looked in Malcolm's files and found this:Hi Malcolm,
Many thanks, Jon
No problems.Thank you LostKiwi, exceedingly useful.
Can anyone adivse the best for cleaning out the one located by the fuel filler cap? Mine's completely blocked. W124 cabrio from '91.I've looked in Malcolm's files and found this:
