ajlsl600
- Nov 18, 2013
- Location
- france
- clk3202001,sl6002003 with everything regrettably sold ,A class 170cdi auto. NG/TF1800 ML250
thought i would try this..
think of all the gimicks and related tech on yr car . what would you consider a useful addition . for example
i ,yrs ago worked on an old car,i think a riley ? . and it did not have the useless jack that comes with most ,even very expensive cars ,it had 4 electric jacks built into the outrigger xmembers , jacking up the car involved opening a dash panel and flipping a switch ... that WAS useful... even if only to inspect the brakes ... i accept, modern cars do not often get punctures
on a modern note i would like a system for ABC that provides the driver with a way to get home ,if a strut collapses , like metalastic bushes to fix on , after all ABC is not exactly known for being trouble free , a high press filter on the system ,to filter out crap BEFORE it gets pumped through yr ABC valves would be a reasonable upgrade . filtering the return,is simply, the cheapskate way out .
