Mercedes-Benz Owners' Forums
Reply
Thread Tools Display Modes
  #1
Old 20-03-2017, 07:17 PM
Big Cheese Big Cheese is offline
Junior Member
Car: ML63 2007
Default Check Oil level at refuelling
I have a 2007 ml63amg that has displayed check Oil level at next refuelling.
Have checked & level appears fine.
Does anybody on here have any clues on this?
Sent from my STV100-4 using Tapatalk
  #2
Old 20-03-2017, 08:25 PM
EmilysDad EmilysDad is offline
Car: R320 2007
Default
Different engine, but my car is very finicky re the level and often gives the same message. Needs to be checked when warm
  #3
Old 21-03-2017, 06:15 AM
Steve@Avantgarde Steve@Avantgarde is offline
Car: Mercedes-Benz C32AMG and SLR Coupe 2005.
Default
As above. Might need as little as 1/2 litre.
__________________
Avantgarde Automotive, Unit 14 Hither Green Trading Estate, Clevedon, North Somerset, BS21 6XU
01275 217270/07967 042960
https://twitter.com/AvantgardeMB
  #4
Old 21-03-2017, 10:50 AM
Junior Member
Threadstarter
Car: ML63 2007
Default
Thanks for the replies I've added a litre which has bought it to the maximum.
Hopefully this sorts it out.
  #5
Old 22-03-2017, 05:51 AM
Junior Member
Threadstarter
Car: ML63 2007
Default
still getting check oil level at refuelling warning come up on dash.
have rechecked level & its at maximum anybody have any ideas?
  #6
Old 22-03-2017, 09:51 AM
John Laidlaw's Avatar
John Laidlaw John Laidlaw is offline
Car: W212 E63 AMG V8 Biturbo
Default
You certainly dont want to overfill it!
Might it need a reset Steve?
__________________
John
  #7
Old 22-03-2017, 11:32 AM
Mark A Mark A is offline
Car: 08 ML-420CDI, 58 ML-320CDI, 55 SLK-350
Default
Failed level sensor ??
__________________
If you can't fix it with a hammer, you've got an electrical problem.
Current
2009 (58) ML-320 CDI Sport
2005 (55) SLK-350
2008 (08) ML-420 CDI Sport
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Check oil level with no disptick alexanderfoti Engine, Drivetrain, Fuel and Exhaust 9 05-08-2015 11:45 AM
W211 E320 CDi - Engine Oil Level Measurement, again! Razoo Engine, Drivetrain, Fuel and Exhaust 17 20-06-2015 07:57 PM
W204 - Check oil level when warm or cold? moj91 Engine, Drivetrain, Fuel and Exhaust 9 11-02-2015 01:49 PM
(W211) DIY Guide for Differential Oil Change Knightkiller Engine, Drivetrain, Fuel and Exhaust 0 22-03-2012 03:32 PM
05 C200 Classic SE Auto Komp Oil Level Check Scuderia Engine, Drivetrain, Fuel and Exhaust 2 27-08-2011 03:10 PM
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
