Mercedes-Benz Owners' Forums
Go Back   Mercedes-Benz Owners' Forums > Technical > Engine, Drivetrain, Fuel and Exhaust
Reply
Thread Tools Display Modes
  #1
Old 20-03-2017, 09:03 PM
gazawee gazawee is offline
Car: Vito 113 CDI
Default Where is the DPF Pressure Sensor Vito 113 CDI 2011
Hi everyone,
I need to change my DPF pressure sensor (if I can find it). Does anyone know where it is exactly?
Cheers in advance
  #2
Old 20-03-2017, 09:32 PM
Threadstarter
Car: Vito 113 CDI
Default
Wondering if it's in the engine bay or by the exhaust under the van
  #3
Old 21-03-2017, 11:45 AM
mercedes13156 mercedes13156 is offline
Car: C Class 220 CDi & CLK 200 Cabrio
Default
There should be two, if my i980 is correct. One before the DPF (upstream) and the other just behind it (downstream), so they can measure the pressure difference between the two, caused by the amount of particulates in the filter.
  #4
Old 21-03-2017, 06:55 PM
Threadstarter
Car: Vito 113 CDI
Default Hi
What's an i980?
The sensor I need to change is this one:[URL="https://www.worldcarparts.co.uk/exhaust-pressure-dpf-sensor-for-mercedes-a-b-cla-cls-e-s-m-vito-sprinter"]
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Error Codes WebsterMB Electrics, Vacuum, Ignition and ECU 19 16-01-2015 02:13 AM
The GAD WT4 System update!!! GAD Tuning LTD Tuning, Styling and Performance. 0 18-12-2013 07:52 AM
mercedes c22o cdi dpf adamkg85 Engine, Drivetrain, Fuel and Exhaust 6 25-07-2013 04:46 PM
CDI Fuel Pressure - The list goes on Cnics Engine, Drivetrain, Fuel and Exhaust 5 01-03-2009 08:57 PM
Broken fuel pipe from pressure relief valve 210 220 cdi Matt_EClass Engine, Drivetrain, Fuel and Exhaust 9 15-02-2009 10:27 AM
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
