Old 05-11-2013, 06:18 PM
moj91 moj91 is offline
Car: '09 W204 C-Class 250 CDi, '05 W220 S-Class 320CDI (AMG Kit), '03 W168 A-Class 170CDI LWB Elegance
Question W204 - Check oil level when warm or cold?
I've recently bought a W204 (S204 Estate...) C250 Cdi, and noticed that it has an old-school dipstick for checking the oil level. I have two questions -
1.) Does it need to be checked when warm, or cold, or ie. 10 minutes after stop? I can't find anywhere where and when it is supposed to be checked.
2.) How much oil is the difference between the minimum and maximum oil levels so if it needs topping up i can work out how much to put in?
Thanks!
Old 05-11-2013, 06:28 PM
Cole@MBS's Avatar
Cole@MBS Cole@MBS is offline
Car: 124 300 CE 24 Coupe, 209 240 CLK
Check it 10 mins after turning off, 3/4 on the stick before max is good......
M.B.S
Mercedes Benz Specialist
Star Diagnostics / Servicing, Brakes, Repairs
Woolston, Southampton. Tel: 02380 445820
The Following 3 Users Say Thank You to Cole@MBS For This Useful Post:
BAZZER1 (11-02-2015), C350Carl (11-02-2015), television (05-11-2013)
Old 05-11-2013, 06:46 PM
turbopete turbopete is offline
odd this, as MB seem to say to check when warm BUT when I was serving my time at college etc, they (and most, if not ALL manufacturers at the time) said it should ideally be checked BEFORE the engine had ever been started (ie 1st thing in the morning etc) as opposed to 10 mins AFTER a run!
Personally, i still do it 1st thing, as a rule
Old 05-11-2013, 06:49 PM
Oil that will run down will do so in 10 mins, any other oil dripping after that would not fill a tea cup and still be warm enough to allow for expansion.
Old 08-11-2013, 10:51 PM
The 10 minutes after seems a good shout, and was the same i have seen on any other cars i have had/used/worked on...
Old 09-11-2013, 07:27 AM
tode's Avatar
tode tode is offline
Car: S350 btec
If you check the level when the engine's cold jusy remeber that the level will rise a few mms when it's hot.
Old 09-11-2013, 08:38 AM
coventryslk coventryslk is offline
Car: W204 CDI Sport
I do the same, all the oil in the sump and car on lever ground
Another Mercedes
Old 09-11-2013, 08:41 AM
Car: W204 CDI Sport
Originally Posted by moj91 View Post
Thanks!
Yes my W204 has the dipstick too and i check the oil when the car is on a level surface. My old yr 2000 megane had onboard oil level indicator as well as a dipstick also my Laguna2ph2 2006 had the same, yet i never needed to top up oil between changes but was a nice touch when starting the car to know your oil level
Another Mercedes
Old 11-02-2015, 01:01 PM
Tour De France Tour De France is offline
Car: C250 CDI BlueEfficiency AMG Sport Plus
Mo matter what engine , I've always tested the oil level COLD and of course on level ground
Old 11-02-2015, 01:49 PM
C350Carl's Avatar
C350Carl C350Carl is offline
Car: 2013 E250 CDI AMG Sport Estate
Why do you need to check the dipstick?
I just treat it the same as screenwash and fill mine up until it reaches the top of the spout for the dipstick. Never understood why you have a dipstick. Just keep it topped up and jobs a good 'un.
* I am joking in case some intellectually challenged person can't understand sarcasm!
Tags
dipstick, oil, oil level, w204
(W211) DIY Guide for Differential Oil Change Knightkiller Engine, Drivetrain, Fuel and Exhaust 7 11-12-2014 12:36 PM
how do you check gearbox oil level on e270 jenny1 Engine, Drivetrain, Fuel and Exhaust 6 07-12-2010 07:02 AM
E320 CDi Engine Oil Level Check Razoo Engine, Drivetrain, Fuel and Exhaust 6 04-12-2008 02:58 PM
Help Please -How Do I Check W202 Auto Gearbox Oil Level SeaGS Engine, Drivetrain, Fuel and Exhaust 2 16-02-2007 03:04 PM
Enging Oil level in CLK230 Dave3622 Engine, Drivetrain, Fuel and Exhaust 0 20-10-2003 12:26 PM
