Old 04-08-2015, 09:45 PM
alexanderfoti's Avatar
alexanderfoti alexanderfoti is offline
Car: W221 S65 AMG, C203 220 CDI
Default Check oil level with no disptick
So I did an oil change on the R230 the other day.
I cannot in any way, shape or form, get the stupid dyno mode/oil level screen to show up on the dash.
Key on, reset button 3 times whilst on odo/temp screen, no beep nothing.
This engine has no dipstick, only the cap, so I thought, AHA, I Will get star on it, and that will show me the oil level.
It does show me the oil level......... in MM!!! What use is that!!!
Is there anyway for me to check the oil level on this car?
Alexander Foti
Old 04-08-2015, 09:53 PM
star's Avatar
star star is offline
Car: Smart + others :)
It shows in mm and there should be a spec range next to it.
Star Motor Service Ltd
Mercedes Specialist In Reading
0118 9462750
www.Starmotorservices.com
www.Starmotorservices.co.uk
Old 04-08-2015, 09:55 PM
Just found that in DAS Sim on my indoor computer, on my Xentry laptop it didn't show a range next to it at the time!
I put in 7.4 L, WIS shows oil fill with filter at 7.5 so its got to be in the right range anyway. Dash says oil level "OK" (thanks!)
I assume the range represents the dipstick, so near the top end of the range is ideal for next time?
Alexander Foti
1. Insert key into ignition and switch to position “1”
2. Press menu button or until the main mileage display is shown.
3. Press reset button R (1) and hold for 3 seconds.
4. The message "DO YOU WANT TO RESET THE SERVICE INTERVAL? “CONFIRM WITH R BUTTON” displays.
5. Press button R (1) again.
6. Switch off ignition and remove the key.
Old 04-08-2015, 09:57 PM
That's for resetting the service interval, I'm looking for the oil level display in Liters.
However, now you mention that, I couldn't get that to work either, I had to go into ICM via STAR and input the service that way.
Alexander Foti
Old 04-08-2015, 10:04 PM
I think I will go to bed Alex
alexanderfoti (04-08-2015)
Old 04-08-2015, 10:29 PM
Hehe
Sent from my HTC One M9 using Tapatalk
Alexander Foti
Old 05-08-2015, 06:35 AM
V6Matty V6Matty is offline
Car: Peugeot 508 RXH (His) W169/2005/A180 (Hers)
We forgive you Malcolm, we all know your heard if full of you old 230 now
Please donate to a good cause
https://www.justgiving.com/alzheimerssoc
Matt
The Following 2 Users Say Thank You to V6Matty For This Useful Post:
John Laidlaw (05-08-2015), television (05-08-2015)
Old 05-08-2015, 09:07 AM
AMGeed's Avatar
AMGeed AMGeed is offline
Car: 2004 E55K ///AMG
Alex, I had a similar problem at my last service at MBS. Colin did the oil change, put in the 8.5 litres but couldn't get the level to come up on the display.
In the end, he had to re-programme the feature back with star as he said at some point it had been coded out.
[SIGPIC]Secondary cats & resonator deleted x-pipe fitted. Carbon diffuser. Lowering links.
At some point in life, everyone has gambled on a fart and lost.
The Following User Says Thank You to AMGeed For This Useful Post:
Old 05-08-2015, 11:45 AM
Its funny you say that, I have heard another Indy mention that I may need to re-code the cluster.
I will look further into that option!
Alexander Foti
Oil labelling explained oilman Engine, Drivetrain, Fuel and Exhaust 120 07-12-2016 12:15 AM
W211 E320 CDi - Engine Oil Level Measurement, again! Razoo Engine, Drivetrain, Fuel and Exhaust 17 20-06-2015 07:57 PM
W204 - Check oil level when warm or cold? moj91 Engine, Drivetrain, Fuel and Exhaust 9 11-02-2015 01:49 PM
(W211) DIY Guide for Differential Oil Change Knightkiller Engine, Drivetrain, Fuel and Exhaust 0 22-03-2012 03:32 PM
Buying Oil, Some Basic Advice From Opie Oils oilman DIY: Engine, Drivetrain, Fuel and Exhaust 1 31-07-2009 02:55 PM
