Old 14-12-2016, 09:34 AM
Dere Dere is offline
Car: E320 2005 3.2
Default W211 E320 LHD Blowing cold air problem, need some information
Hi guys,
A little headache with blowing cold air on W211 E320.
So sometimes it blows hot air sometimes not.
Main common problem is heater valve under wipers.
I expected that, but there is some non-sense about that. Let's say there is one incoming hose to it, 2 pipes to heater core, and one hose outgoing. Then normally those two pipes to heater core would be one is inlet one is outlet (I'm correct?). So lets say engine is warm in working temperature, i took out plastic under the steering wheel, and upper pipe is hot, and down pipe is cold, and interior keep blowing cold air everywhere.
So as I understand that valve works, so why there is no hot air? Is there some kind valves near heater core or what? Normally if inlet pipe is hot and outlet pipe is cold, something is blocking it. And the strangest thing that lets say 4 days it works OK, and then for a week or so not working, and it starts working again when ever MB wants
Any ideas what and where to check?
Old 14-12-2016, 10:29 AM
Car: E320 2005 3.2
OK, i expect that MB control heat over outlet, not inlet like in bmw.. so it may be stuck exchange valve... yes?
Old 14-12-2016, 11:58 AM
Frontstep Frontstep is offline
Car: T210 320cdi
You could clean it,
or replace it http://www.benzworld.org/forums/gene...r-problem.html
Old 14-12-2016, 01:01 PM
AMGeed's Avatar
AMGeed AMGeed is offline
Car: 2004 E55K ///AMG
Have a look at one that wasn't working to see what can happen to them.
Pig of a job to replace as well.
[SIGPIC]Secondary cats & resonator deleted x-pipe fitted. Carbon diffuser. Lowering links.
At some point in life, everyone has gambled on a fart and lost.
Old 14-12-2016, 01:35 PM
Car: T210 320cdi
Whats that been in the north sea ?
Old 14-12-2016, 02:39 PM
mersum1es mersum1es is offline
Car: W211/-04/320CDI, W210/-01/270CDI
my valve:
http://forums.mercedesclub.org.uk/sh...6&postcount=13
Old 14-12-2016, 02:59 PM
AMGeed's Avatar
It does look like it. That was how it looked when Colin at MBS removed it in Dec 2014.
Old 14-12-2016, 03:05 PM
Some people just give them a whack and they come back to life again, but not when they are as bad as the one be Mr Geed
Old 14-12-2016, 03:51 PM
AMGeed's Avatar
No amount of whacking would have brought that back to life
Old 14-12-2016, 03:54 PM
I know but there are still some folk who just give them the annual whack
w211 e320 cdi vibrating problem Bobby Abraham Engine, Drivetrain, Fuel and Exhaust 5 05-04-2012 09:03 PM
heater blowing cold air jacs211 Electrics, Vacuum, Ignition and ECU 7 20-06-2011 07:32 PM
Vaneo W414 heater blowing cold air only ml320cdi Electrics, Vacuum, Ignition and ECU 0 20-06-2011 11:14 AM
W211 - Heater Blowing Cold Warrior Engine, Drivetrain, Fuel and Exhaust 30 03-05-2011 09:04 AM
Sprinter heater Blowing cold air! tipperman Engine, Drivetrain, Fuel and Exhaust 0 28-11-2008 04:07 PM
