Old 13-02-2008, 02:38 PM
brandwooddixon brandwooddixon is offline
Car: CL500 - 2004 model with loads of toys
Default How to replace W210 ARB drop lilnks and bushes
Its a common problem with W210s, especially for areas infested with speed calming measures, your drop links will become worn, resulting in knocking from the front suspension and high frequency vibrations after passing over bumps.
Replacement of these parts can be performed with the vehicle on ramps, although if you have access to a lift it would undoubtably be easier.
Time taken: about 1.5 hours
cost:
drop links 6.70 +VAT each
ARB bush 3.95+VAT
Bolts 90p+VAT each. or treat the old ones with thread lock when refitting
Tools:
13mm or 1/2" socket
T50 Torx bit
Silicon spray grease
Torque wrench
Here're my pictures for this operation:
1. If it hasn't already been done place a mark on the anti-roll bar so that when you come to reinstall it you can ensure that it is located centrally to the chassis. I put a blob of paint in the middle in line with the centre of the gearbox.
2. Undo the T50 torx bolt at the bottom of the drop link. These bolts will probably have been treated with thread lock and may be troublesome to remove.
3. Undo the four 13mm bolts which attach the anti-roll bar to the chassis. Be careful, the bar is heavy and give you a good bruise if you're not ready.
4. With the bar removed you'll need to remove the old drop links from it. They are only a push fit but will probably be troublesome.
5. The main ARB bush holder will come apart into two pieces. Try and remember the location of the heat shield for reinstallation. Slide the bush off the end of the bar.
6. If it's been a long time since they were last replaced you'll probably notice some bad pitting and rust underneath the old bushes. Best to clean and treat.
7. Spray a light covering of silicon grease or something similar over the bar to make it easier to install the new bushes.
8. The new drop links are handed. It's best to install them before installing the ARB as when underneath the vehicle you may not be able to get sufficient leverage to pop them over the ends of the bar. The rubber "ear" faces away from the lower wishbone and towards the car centre line.
9. Replacement is now the reverse of removal. Don't tighten up the bolts until you are sure that the ARB is centralised.
Torque settings:
ARB bush bolts to chassis: 20Nm
Drop link to lower wishbone: 80Nm
The Following 13 Users Say Thank You to brandwooddixon For This Useful Post:
9derekt (12-05-2010), BAZZER1 (26-10-2016), brens-e200 (24-03-2010), E320 Limo (25-10-2016), HERBIEMERCMAN (26-10-2009), m davies (25-02-2011), pitch1 (11-05-2010), qurm (12-04-2010), S.Speed (19-11-2010), snispo (13-01-2011), tezz (22-10-2009), Virgil Solozzo (31-10-2014), withinm (24-06-2010)
Old 22-10-2009, 02:35 PM
HERBIEMERCMAN's Avatar
HERBIEMERCMAN HERBIEMERCMAN is offline
Car: 97. E300.TD. 7 SEAT.ELEGANCE. EST.TOYOTA SUPRA MK4. RS. VAUX. CORSA.GLS AUTO. SPORT.
Question W210 drop liks.
hi blob, good post you have provided. if i disconnect the drop links and then drive over some bumps and the knocking stops, then is this a sensible way to see if my drop links are the knocking problem ? i had the drop links changed 30k back but the rool bar bushes have never been changed ? i have 193k on the clock. best wishes. herbiemercman.
Old 22-10-2009, 03:04 PM
Markieboye Markieboye is offline
Car: W210 E320CDi Estate 255000 miles
If they are that worn, then it will be obvious when you look at them.
For what the bushes cost, and you are about 1/2 way there in doing the job, you might as well get on with it
BTW: I replaced the drop links by holding the arb upright, links on the ground, a hard push with 'attach' them to the end of the bar and then a lift and a sharp hit on the ground with pop them on properly. HTH
Mark
The Following User Says Thank You to Markieboye For This Useful Post:
HERBIEMERCMAN (23-10-2009)
Old 22-10-2009, 03:41 PM
I will ask to have it put in the DIY section
Old 07-11-2009, 04:47 PM
if you do one side at a time, you do not need to disturb the antiroll bar, this eliminates the repositioning of this item. the front ARB'S bushes are easy to push over the ends of the bar with some silicon grease, the rear ones are split so even easier. brandwood's post is first class, but the points mentioned make the job even easier. the worst case scenario is the hex allen key studs retaining the rear bushes, badly corroded on most cars and inaccesible. herbiemercman.
Old 26-11-2009, 01:53 PM
ben12345 ben12345 is offline
Well I just attempted changing the front drop links on my ARB... One was an advisory on a recent MOT, and I do notice a slight knock from the front on occasion.
It was one of those few occasions that I actually bought genuine parts! I wished I hadn't have bothered though - As soon as I started pushing the new link onto the end of the bar, the bush split and popped out! I'd even warmed it up in hot water, and was using plenty of washing up liquid.
Upon closer inspection, the bush in question was hard and brittle, and not supple like i'd known new bushes in the past to be.
What do you think the dealers response is going to be? 'You must have been installing it incorrectly'?
I bet this 'new' part has been sitting on their shelf in the sun since 1996.
I didn't bother trying the other side.
Ben
1985 Porsche 928 S2 Black/Black
1985 MBZ 500 SEL Black/Navy - 5.6
1990 BMW 750i Black/Black
1996 MBZ E300D Silver/Grey
Old 08-12-2009, 04:54 PM
Well Kudos to Mercedes! They replaced the link with no questions asked!
Have now replaced both sides and my slight knocking noise has gone.
Ben
Old 10-12-2009, 05:38 AM
Result!
Glad it all worked out.
Methinks that it's time again for me to replace the bottom ball joints and check the drop links, arb bushes and steering ball joints.
Chris
CL500 2004
E430 Avantgarde Saloon 1998 - gone but not forgotten
Old 10-12-2009, 09:46 AM
Yeah, I was surprised at how easy the suspension parts on this car are to replace.
I remember trying to change the bottom ball joints on my w126. That was a PITA!
The bolt on ball joints on the W210 look like a dream to change.
Ben
Old 09-02-2010, 10:44 AM
nick73 nick73 is offline
Car: w209, CLK 280 Convertible
Hi fellas,
Great write up, thanksbrandwooddixon
Just wondered though,
1- if I do one side at a time to avoid removing the ARB, can I do this by just jacking the car up?
2- If I asked for 'w210 front suspension drop links' at the dealer, will that be all I need to tell them?
Many thanks!
Nick
