Old 09-08-2009, 09:24 PM
tobycousens tobycousens is offline
Car: CLK350 Cabrio
Default Tow bar & electrics for CLK350 W209 Cabriolet
I've just bought a couple of bikes for my wife and I, and assumed wrongly that finding a bike rack for this car would be simple! How wrong I was. It seems the best bet now is to have a detatchable tow bar fitted and go for a Thule Bicycle Tow Ball Carrier http://www.car-roofracks.co.uk/ride-...le-carrier.htm
The surprise problem was trying to find a manufacturer of Tow bars that supports the W209 CLK Cabrio (55 plate) along with electrics. The Bosal referred to on this thread was for an older model - http://forums.mercedesclub.org.uk/sh...bar+clk&page=2
The Witter version here http://www.towequipe.co.uk/1/1/48674...riolet-03.html looks fine, but doesn't have any electrics! Clearly I don't really have a clue what I'm doing, and will ask a pro to fit it, but it would be good to get any ideas from anyone what the best bet here is, whether the carrier, or the Tow Bar?
Cheers
Toby
Old 09-08-2009, 10:00 PM
Hello and welcome,,do you need the electrics for a cycle rack
Old 10-08-2009, 06:46 AM
Car: CLK350 Cabrio
Hi Malcolm, thanks for the welcome. I'm at a starting point of having the car and the bikes - nothing else! So as far as I can gather the cleanest way is to have a detatchable tow bar installed, which would need the electrics to go with it, then to have a cycle rack complete with lighting and plate rig like one of these http://www.car-roofracks.co.uk/ride-...le-carrier.htm
I just can't find a make of Tow Bar that comes with electrics for the W209 CLK. As Witter make a bar that fits, at least knowing where to get the electrics rig for a tow bar would be great!
Cheers
Toby
Old 10-08-2009, 10:57 AM
MB do a special kit for this, it plugs into the rear of the car
Just ask at your MB dealer,,they are very easy to wire in
The info you require comes on paper number
AN31 19p 8100 05qa
Or I can send you this info
Old 10-08-2009, 11:32 AM
bouncer bouncer is offline
Car: C200k w203
Try right connections 01952 249333 for towbar electrics kits.
sTeVe
Old 12-08-2009, 09:37 AM
Car: CLK350 Cabrio
Thanks guys, much appreciated!
Tags
bike, cycle, tow, tow bar, towbar
Tow bar electrics Wingnuts Electrics, Vacuum, Ignition and ECU 12 08-11-2012 06:37 AM
S211 Tow bar electrics Spannaz Electrics, Vacuum, Ignition and ECU 6 11-02-2012 05:31 PM
Fitting a Tow bar and electrics to a W211 Dosco Electrics, Vacuum, Ignition and ECU 15 04-03-2011 10:39 PM
Fitting a Tow bar and electrics to a W211 Dosco DIY: Electrics, Vacuum, Ignition and ECU 1 27-09-2010 08:14 AM
w202 C180 tow bar electrics golfcarmad Electrics, Vacuum, Ignition and ECU 1 24-02-2008 05:09 PM
