Go Back   Mercedes-Benz Owners' Forums > Technical > DIY > DIY: Bodywork, Wheels & Trim
Old 17-02-2010, 06:34 AM
palmbay palmbay is offline
Default W203 - C220 CDI - Removal of Ashtray and gear knob surround
Firstly remove the ashtray inner as per normal cleaning.
Remove the Gear surround by gently lifting upwards,
ensure ashtray lid is open to prevent scratching by
the metal clips.
Lift up until clips are clear then slide forward to release rear edge.
Lift up and over gear knob to reveal the gear knob release mechanism,
which should be twisted anticlockwise, (if I remember rightly!).
Twist the gear knob until it releases,
then lift up. Don't forget to unclip the small electrical
connection underneath (or to put it back on, when reassembling).
Gently prise the 2 ashtray holder retaining clips back whilst lifting holder upwards.
Note next to clip is where the gear knob surround clips into (Scratches).
Twist about and manoeuvre the ashtray holder past the gear stick. Beware of wires attached to the holder underside.
Mark up, and unclip the 2 wires from the holder assembly.
Lift clear. Reassembly is just a reversal.
The Following 6 Users Say Thank You to palmbay For This Useful Post:
BIGCJL (25-07-2011), littledigger (15-10-2010), Madtek (10-05-2010), tasinga2 (17-09-2010), Tju (28-05-2012), Zebra (04-06-2010)
W203 - C220 CDI - Radio/CD Head removal palmbay DIY: Electrics, Vacuum, Ignition and ECU 1 17-02-2010 06:03 AM
Wooden gear surround on 129 SL PritJutla Bodywork, Tyres, Wheels & Trim 1 27-03-2003 09:19 AM
