Old 11-07-2010, 12:09 AM
aby k aby k is offline
Default Advice Needed...key wont turn
Hi everyone New on here and need some advice....
i have 2001 Mercedes C220 cdi auto 84k, the remote key unlocks the car, mileage display lights up but when i put the key in the ignition nothing happens it doesn't click or turn. battery is ok the headlights turn on & off, remote central locking works on both keys. I've had a booster on the battey to give it a kick start but still nothing. the car was running fine prior to this, i'd only parked it 10 minutes before the problem occured.
Any help & advice will be much appreciated.
thanks in advance.
Old 11-07-2010, 12:17 AM
dieselman dieselman is offline
Car: A diesel
That sounds like the EIS (electronic ignition switch) has failed, if so you need a new EIS and a green key to program the key too it.
It would be worth making sure the power and CAN connections to the EIS are good before ordering a new switch.
Have a STAR test to be sure.
Old 11-07-2010, 08:16 AM
wemorgan wemorgan is offline
Car: R172 SLK 250CDI
I had a similar situation once parked outside a friend's house, trying to start the car for 5 minutes to no joy. Eventually saw that the gear was in 'D'. Moved it to 'P' and the engine came to life.
I'm sure you're not as silly as me, but thought I'd share this incase it's the solution.
Will
Old 11-07-2010, 09:45 AM
rapide rapide is offline
Car: 1997 E230 (no rust)
Default wont start
good point! sometimes the silly or to obvious are the answer, as the AA / RAC men say, start with the easy stuff first! you never know! before you dig deeper!
Old 12-07-2010, 05:26 PM
The transponder coil can fall off in the key and the locking still works when this happens
Old 12-07-2010, 08:54 PM
Cheers guys for responding, car is definatley in park, I left the car outside a mates house as I'm away with work but he went to the car last night had a fiddle with key & got it to turn!!!! Anyway he parked it on my drive for me but when my wife tried the same thing again key wouldn't turn. Definatley sounds like something with the ignition.
Old 12-07-2010, 09:04 PM
If this is a 210 then the EIS switches can fail,, do you have a spare key
Old 13-07-2010, 06:12 PM
It's a 2001 51 reg c220 cdi not know what model, yeh I've tried the spare key & that doesn't turn. I spoke to my friend he tried to start the car again and it wouldn't. So back to square 1.
Old 13-07-2010, 06:41 PM
Then the EIS switch on the way out
Old 13-07-2010, 06:58 PM
How can I get the car into neutral from P to get the car recovered to a garage.
ignition key wont turn woolfie8 Electrics, Vacuum, Ignition and ECU 7 26-06-2013 06:33 PM
Central locking from key not working, cannot turn key yowl Electrics, Vacuum, Ignition and ECU 2 16-09-2012 03:31 PM
C180 (94) ignition key won't turn daveseavista Electrics, Vacuum, Ignition and ECU 5 13-08-2010 01:23 PM
Key won't turn in Ignition (sometimes) DiscoPistol Electrics, Vacuum, Ignition and ECU 19 28-06-2010 11:11 AM
Help needed - W124 E320 key won't turn westcliff General Mercedes-Benz Related Discussion 5 07-08-2008 07:37 AM
