Old 09-10-2010, 08:44 PM
bruno2009 bruno2009 is offline
Car: W203 CLC 220 Sport
Default W 203 Saloon Led Number plate light change
After some research i have now changed my number plate lights to Led ones.
Here are the instructions on how to do the change and from start to finish should be no longer than 1 hour.
The tools needed are
T20 Torx driver
8mm socket and ratchet
Phillips screwdriver
Small flat bladed screwdriver
Butter knife or spatula out of the kitchen
1 - You need to remove the emergency warning triangle and then the boot liner' to do this you need your T20 torx driver and remove the 2 srews either side of the boot lock.
2- Remove the bracket that holds the warning triangle in place by sliding to the left.
3- Using your small flat bladed screw driver you need to remove all the plastic clips that hold your boot liner in and the 2 plastic covers that cover each hinge,after doing that the liner should now pull off.
4- Remove your number plate and if it as a rectangle frame you need to remove that by unscrewing the 4 phillips screws.
5-In the centre behind where the number plate was' you will see a small round head bolt and to remove that you need to look inside the boot lid and you will see the nut which can be removed with the 8mm socket and wrench.
6- You then need to remove the plastic cover which your number plate was attached to' This is where you use either a butter knife or spatula which should be covered in tape so it will not damage your paintwork.
You need to lever the cover off it has 4 clips at the top and 4 at the bottom, It will just pop off with a bit of force but take care because you might break the clips.
7- you now need to unplug the light and release the old lights,by pressing the clip which is on the left hand side of the light through the boot lid and the light will pop outwards.
8-Plug in your new light and test and then fit everything back in reverse order and you have now finished.
One picture with 1 old light and new one and then both new ones fitted.
The Following 2 Users Say Thank You to bruno2009 For This Useful Post:
S.Speed (09-10-2011), Zebra (19-03-2011)
Old 09-10-2010, 08:50 PM
turbopete turbopete is offline
any problems with the bulb failure warning on the dash? or do these units have the necessary resistors built in?
Old 09-10-2010, 09:05 PM
No problem what so ever' so i assume they have a resistor built in.
The Following User Says Thank You to bruno2009 For This Useful Post:
turbopete (09-10-2010)
Old 09-10-2010, 10:19 PM
aquanaut's Avatar
aquanaut aquanaut is offline
Car: 2012 C63 AMG
thank you for the post, most informative! my offside light has gone. Where did you purchase the bulbs?
Old 10-10-2010, 10:38 AM
I will try and find the link to the ebayer i purchased from.
Old 10-10-2010, 10:54 AM
Here is the link to the person who i got mine from
http://cgi.ebay.co.uk/Mercedes-Benz-...item1c0d3dfd49
If buying lights for a Saloon you will need the Sedan ones and not the wagon ones they are for an estate model.
Old 10-10-2010, 10:59 AM
SheriffJW SheriffJW is offline
Car: C250cdi Blueefficiency Sport Saloon
A mate of mine got burned with these last week for his 325i.
He had to fork out more than double the money to get the right ones that didnt bring up dash error.
Always check before you buy.
Old 10-10-2010, 07:15 PM
I can assure anyone buying these will not be dissapointed, I have just checked mine and cannot believe how bright they are.
Old 19-03-2011, 12:28 PM
hawkeye hawkeye is offline
Car: w211/07/280 CDI
Default Small tip
Thanks very much for this - I was really struggling to work out how to get the plate cover off.
A small tip - instead of levering it up using a knife I squeezed the four bottom "clips"/"poppers" internally, using a pair of thin pliers. It then it popped up by itself enough for me to get my hand underneath (from the outside) and pull the top part out manually. No sharp implements required
Hope this helps a few people with their paintwork !
07 e280 CDI sport - driving heaven !
05 C200K - loved until someone ran into me
04 C200 CDI - Sticky Gearbox - Gone
Old 19-03-2011, 12:54 PM
HelpThisDude's Avatar
HelpThisDude HelpThisDude is offline
Car: W203 C270CDI, R172 SLK55 AMG
Wow 23+15 delivery!
I bought led bulb replacement, with the resistor built in. Think they were about 7, still workng on my car now after 9 - 11 months (cant remember for sure), The Item no longer exists, but this unit looks the same:
http://cgi.ebay.co.uk/MERCEDES-BENZ-...item1e61d2c172
I cant vouch for this Item, but the one I bought works great, for a lot less money.
The Following User Says Thank You to HelpThisDude For This Useful Post:
television (19-03-2011)
New Number Plate Light Unit sfc501 Electrics, Vacuum, Ignition and ECU 7 02-04-2013 07:38 PM
White number plate bulbs - not LED? kredol Electrics, Vacuum, Ignition and ECU 7 15-04-2011 08:39 AM
Number plate light Just Phil Electrics, Vacuum, Ignition and ECU 5 15-07-2010 06:22 PM
W124 number plate light not working jbn Electrics, Vacuum, Ignition and ECU 3 04-12-2008 02:06 PM
A Class Number Plate Light toshington1 Electrics, Vacuum, Ignition and ECU 1 05-09-2008 07:45 AM
