Old 11-05-2012, 11:40 AM
Dosco Dosco is offline
Car: W211
Default Cabin Air Filter
..not the 'pair' that fit above the passenger foot-well but the one under the bonnet (hood).
There are TWO part number variants for this filter that I do know but here lies my confusion.
Checking the MANN site I though I had sussed the correct one indeed it was confirmed by MANN as correct.
So checking prices as one does I call my MB spares department and having given the chassis number I find that they are quoting the 'other' filter - which to be fair is over £7.00 cheaper.
Checking the service invoices/records I had with the car from the previous owner I find that the more expensive filter had been fitted by his MB garage which ties in with the MANN filter part number ans price (give or take a couple of £'s)
Now whilst I do not doubt that my local MB spares dept is wrong I do not want to fit the wrong one neither do I want to pay for a more expensive item if not needed - so can someone help throw light on the subject.
My car has THERMOTRONIC 4 ZONE A/C system fitted - sales code 581, whatever that might mean?
Old 11-05-2012, 11:44 AM
Originally Posted by Dosco View Post
.. so can someone help throw light on the subject.
Dosco (11-05-2012)
Old 11-05-2012, 11:48 AM
Car: W211
Originally Posted by television View Post
I need that don't I
Old 11-05-2012, 12:22 PM
I just do my best I can look it all up later
Dosco (11-05-2012)
Old 11-05-2012, 12:28 PM
Car: W211
Thanks Malcolm appreciate it. I think that the MB part number IS: -
A211 830 00 18
which equates to the MANN Filter Part: -
CUK3172/1
Old 11-05-2012, 12:38 PM
310 2118300818 ACT. CARBON FILTER
310 2118301218 DUST FILTER,
Filter/circulating air
Dosco (11-05-2012)
Old 11-05-2012, 12:44 PM
grahamcol grahamcol is offline
Car: 2001 SLK230, 2000 C280 V6
Call me a cheapskate if you like. With the cabin air filter, I tend to shake it out onto a bit of old carpet on the floor to get rid of the trapped particles. Then I simply put it back. Saves a few quid and seems to work perfectly for me. Don't think I'd do it with an oil filter though !
PS. It's actually more a matter of banging it (dirty side down, of course) on to the carpet, if you see what I mean !
The Following User Says Thank You to grahamcol For This Useful Post:
Dosco (11-05-2012)
Old 11-05-2012, 01:26 PM
I do the above in between the change interval so after a year. They arent expensive or hard to change, and they keep the dirt and smells out the air in the cabin so worth changing IMO.
Regarding the two different filters available I think you will find one is just a standard filter and the other more expensive one is an activated carbon filter which is obviously better.
The Following User Says Thank You to For This Useful Post:
Dosco (11-05-2012)
Old 11-05-2012, 01:37 PM
Car: W211
Likewise - but after 2yrs it has gone beyond the shake an Vac state
Old 12-05-2012, 07:23 AM
Car: W211
Thanks Malcolm but it is not this one but the one under the bonnet I am on about - incidentally the one shown comes as a pack of two and for the thermotronic system is the first part number you quote.
Thanks anyway.
Air filter housing fixing bolts W203. Exploded diagram help please. Dogfish Electrics, Vacuum, Ignition and ECU 6 15-10-2013 09:19 PM
Unexpected results from changing tyres, exhaust and air filter!! Captain Chris General Mercedes-Benz Related Discussion 17 01-06-2013 10:10 AM
Change air filter on E240/W210? Zarty Engine, Drivetrain, Fuel and Exhaust 2 04-02-2010 12:27 PM
W126 Coupe - Oil in 'Air' Filter!!! silvio13 Engine, Drivetrain, Fuel and Exhaust 17 18-01-2010 02:47 PM
fumes in cabin - smoke from centre of air filter and fumes i p Electrics, Vacuum, Ignition and ECU 5 03-09-2001 06:09 PM
