Old 18-12-2006, 09:14 PM
lambert04 lambert04 is offline
Default no air from vents = blocked pollen filter
lack of air coming out of vents = blocked pollen filter.
just done mine too (thanks for the tips)
thought i would break it down step by step.
first remove the centre console that connects the dash to the floor (box shape) by unscrewing the two 10mm plastic bolts either side of the console. now look up inside the dash, you will see two metal rods, and a big black box. at the back of this box (nearest the engine) is the pollen filter cover.its only a thin strip of plastic. mine was about 12inch long and had this type of pattern on it [X[X[X[X[X[. the pollen filter is under this cover. it slides towards the passenger door (right hand drive van) about two to three inch. it should pull/drop then off. i had to hit it to make it slide with the hook end of a small crow bar between the two metal rods. i then put a long flat screw driver into the corner of the plastic base of the filter and prised it out a bit. then i pulled out the filter. (it broke as it came out). its quite fiddly to get it out though. takes a bit of time. make sure when your pulling it out to move the thin grey wire that runs near it.....
hope this is helps..
Old 19-12-2006, 07:39 PM
Any chance that you could re do it and include the car details,then it can be uesd for reference.
malcolm
Old 19-12-2006, 08:37 PM
C220GJS's Avatar
C220GJS C220GJS is offline
Car: 1995 W202 C220 Elegance
Being psychic I can tell that this is a Vito 108 CDI, sorry can't make out the year.
George
1995 W202 C220 auto elegance,tourmaline green,122k mls,Bilstein shocks.,mine.
2002 Honda CRV,Jan's.
" America would not be in the mess it is in today if the Indians had had stricter immigration laws"-Chief Roy Oshkosh.
Old 19-12-2006, 08:40 PM
Blobcat's Avatar
Blobcat Blobcat is offline
Car: Smart R451 CDI, Porsche 911 C2S, Land Rover 110 County SW, VW Caravelle Executive
I will have a stab at an 2002 Vito 108 CDI
E320 CDI (W211) - Avantgarde 12/2006 - Sold
E320 CDI (W210) - Avantgarde 09/2000, 126kmiles 0-100-0 - Too good to be forgotten
CBR600 - 05/1993
2 x R1200GSA's - 01/2009 (Gone )
Caravelle - Executive 174 03/2007
Old 19-12-2006, 08:42 PM
C220GJS's Avatar
Link to this thread, http://forums.mercedesclub.org.uk/sh...ad.php?t=13404. Touche'
George
Old 28-01-2007, 04:25 PM
sorry, its a vito 02 plate. 110cdi hope this helps you all out.
Old 28-01-2007, 04:46 PM
C220GJS's Avatar
Find your van in here;http://www.detali.ru/cat/oem_mb0.asp?TP=3 ; then heating and ventilation.
George
Old 18-02-2007, 02:36 PM
simon 4166 simon 4166 is offline
Great piece of advice, my heater was rubbish and the whole dash used to vibrate when the fan was on flat out, i ripped out the filter and it is great now!
If anyone is going to do this, i used and allen key to hook the filter out and it worked a treat!
Si
A class w169 centre air vents ctech Bodywork, Tyres, Wheels & Trim 0 22-07-2013 05:48 PM
Air Filter Housing Wobble camerontyler Engine, Drivetrain, Fuel and Exhaust 9 29-04-2011 08:36 PM
w123 fresh air vent closed or blocked TotallyImpractical Bodywork, Tyres, Wheels & Trim 6 08-06-2009 02:45 PM
Pollen filter on 320SLK [170] nine468 Electrics, Vacuum, Ignition and ECU 2 17-06-2008 06:20 PM
W126 high idle after air filter change Fast_Lane_Dane Engine, Drivetrain, Fuel and Exhaust 4 24-04-2008 11:17 PM
