Old 22-03-2012, 10:43 AM
JSeaman JSeaman is offline
Car: CLK 320 1999
Default GUIDE: Changing your Air Filter (W208)
Step 1 - Locate the air filter at the front of the engine bay
Step 2 - Undo the spring clip holding the air box to the inlet pipework
Step 3 - You will find several clips around the air box, simply pull the lower half up and fold the upper half out of the way to release the air box
Old 22-03-2012, 10:44 AM
Car: CLK 320 1999
Step 4 - Repeat for all the clips on the air box
Old 22-03-2012, 10:45 AM
Car: CLK 320 1999
Step 5 - Unclip the hose from the air box, this is flexible and pops out easily
Step 6 - Release the bottom clip from the intake hose (as in step 2)
Step 7 - You can now wriggle the air box clear of the engine bay, be gentle, there shouldn't be much/any resistance
Car: CLK 320 1999
Step 8 - You can now see your (filthy) air filter, simply pull this out
Step 9 - Give the pre-filter side a clean of any leaves/dirt, just wipe with a cloth or similar
Old 22-03-2012, 10:46 AM
Car: CLK 320 1999
Step 10 - Grab yourself a nice new air filter (note the two heights of the filter fins) and lay it in the airbox. Squeeze the edges down so it is well seated
Old 22-03-2012, 10:47 AM
Car: CLK 320 1999
Step 11 - Drop the air box back in, sliding the pipework together first
Step 12 - Note if you want a bit more room, you can depress the tab by the hydraulic rams for the bonnet and allow the bonnet to sit vertically as shown
Step 13 - Refit the clips on the air box
Car: CLK 320 1999
Step 14 - Refit the clips on the induction piping
Step 15 - Pop the hose from step 5 back in place
The Following 2 Users Say Thank You to JSeaman For This Useful Post:
c15htn (07-03-2013), tich65a (21-09-2015)
Old 07-03-2013, 10:59 PM
harp1963 harp1963 is offline
Excellent write up.
The Following User Says Thank You to harp1963 For This Useful Post:
JSeaman (08-03-2013)
Old 08-03-2013, 07:38 AM
Howard's Avatar
Howard Howard is offline
Car: CLS 500 / A 190
Mine doesn't look like that
But a comprehensive write up , agreed , good job !
The Following User Says Thank You to Howard For This Useful Post:
Unexpected results from changing tyres, exhaust and air filter!! Captain Chris General Mercedes-Benz Related Discussion 17 01-06-2013 10:10 AM
[Spares] Air, Oil filter and rear pads. Mike1966 Spares for Sale and Wanted 0 06-08-2011 12:54 PM
Oil in Air Filter & Box vanno Engine, Drivetrain, Fuel and Exhaust 16 05-08-2011 07:27 AM
Air Filter Housing Wobble camerontyler Engine, Drivetrain, Fuel and Exhaust 9 29-04-2011 08:36 PM
E220cdi aventgard 2007 cabin air filter location and access bali420 General Mercedes-Benz Related Discussion 2 07-02-2010 05:36 PM
