Old 23-05-2012, 03:40 PM
S.Speed's Avatar
S.Speed S.Speed is offline
Car: Saab 9-3
Default Update on my Warped Discs
An update re my 6 month old front discs..
In case you didn’t read my original post, I bought a pair of genuine MB discs from my local dealership.
6 months later and 7,000 miles they are warped.
I went into MB today to have my car assessed re a warranty claim for defective discs..
After examination the conversation went something like this:
Mechanic: Youre correct there are the symptoms of warped front discs, but I notice you don’t have original MB pads.
Me: That’s right..Green stuff are actually a little dearer.
Mechanic: And you fitted them yourself
Me: Yes I did..Its not exactly rocket science and in my car owning life time I must have changed 15 or 20 sets.
Mechanic: So you changed them yourself with non standard pads
Me: You have quite a grasp of the situation.
Mechanic: Well I doubt we can do anything because you did it yourself with non standard pads..
Me: I just assumed that THE PART had some sort of warranty in order to at least give customer confidence.
Mechanic: They do when we fit them and they are our parts
Me: The part that has failed ARE your parts !
Mechanic: Would you like me to dismantle and do a written report for 112 + VAT
Me: But you just said I am not covered so what would be the point?
Mechanic: Well it must be the none standard pads..They are too aggressive for road use.
Me: They are Green stuff and are specifically for road use, and I repeat, they are not some cheepo pads from a back street accessory shop..They cost more than the MB ones!
Mechanic: Well do you want to put some standard MB ones in and see if it cures the problem?
Me: Why..Do you think that the MB ones will de warp the discs?
Mechanic: I doubt it
Me: I replaced my brothers discs/pads in his Citroen using parts from Motorcare..His discs warped after 2 months. Motorcare sent the warped discs back to the supplier for examination.. A week later he received a full refund and an apology… We replaced his discs with Brembo ones and they have been fine for the last 8 months… I fitted those discs using none standard pads and it wasn’t a problem when I had to claim they were faulty..
Mechanic: But I have a problem with you doing the work with none standard pads…
Me: We are going in circles here.. I tell you what.. Leave it as it is and I will go to Motorcare for some Brembo discs.. If they should warp then at least I will have confidence in being treated with some common decency.. Your discs are faulty and substandard…
You’ve just lost a customer..
Yet again I am amazed by the lack of common sense here.
A lot of you on this forum predicted the outcome..
I still stand by the fact that a high street accessory shop (WHO KNOW DAMNED WELL YOUR FITTING THE DISCS YOURSELF) will honour a warranty.
I will be getting the Brembo discs and will never use that MB branch again!
Power is how hard you hit the wall....
Torque is how far you take the wall with you !
The Following 2 Users Say Thank You to S.Speed For This Useful Post:
huey (23-05-2012), Mic (23-05-2012)
Old 23-05-2012, 03:47 PM
Sorry they had that attitude Simon, so much for those who say "MB parts are the best"
S.Speed (23-05-2012)
Old 23-05-2012, 04:15 PM
EuroCarParts's Avatar
EuroCarParts EuroCarParts is offline
Car: BMW 2006 330d
Well that sucks :/
There are many dealers who would of brushed it off and supported you, however some will take it to the extreme (fitting 'performance' pads' your self gives them an argument, but there should never be an argument!)
It seems you've got the right attitude - walk away and not shop at that dealer again. Their loss!
The Following User Says Thank You to EuroCarParts For This Useful Post:
Old 23-05-2012, 04:37 PM
M80's Avatar
M80 M80 is online now
Car: Vito115 ExLWB (07)
Simon, fancy putting the pads in upside down. I assume that's how you fitted them incorrectly as back to front would have been a bit noisy.
Martin.
Vito 115 (Auto) ExLWB 07,
K1200RS (2 wheel BMW),
Jeep Grand Cherokee 03.
The Following 2 Users Say Thank You to M80 For This Useful Post:
EuroCarParts (23-05-2012), television (23-05-2012)
Old 23-05-2012, 06:15 PM
cleverdicky's Avatar
cleverdicky cleverdicky is offline
Car: MB
If they have the wear sensor on you cant.
In all honesty I have never known a disc to actually warp, although I'm sure they might.
The closest came once when a new set I had bought and fitted 'warped' and so I put the old ones back on and took the new ones into our then testing workshop. They had all the dial gauges and guys with beards. So after having them checked the guy told me they were to a better tolerance than they could do. Which was impressive for cheapo discs.
I later found out that it was the seat or the back plate that was causing the problem. They did not sit squarely on to the hub. (corrosion, bits of grit etc)
Only 0.1mm grain of grit will prevent the disc seating squarely and could be (and won't be cocky and do the math but a lot) and enough for disc to appear warped at the outside edge.
Might just save some grief just to check.
Old 23-05-2012, 06:23 PM
S.Speed's Avatar
Car: Saab 9-3
I know about being hyper clean when fitting Discs..
I had wire wooled with meths the seating area on the hub.. Then thoroughly cleaned with a rag and brake cleaner..
Remember I fitted these five and a half months ago.. They have warped within the last week.
They were totally fine for 7,000 miles..
Anyway I have psyched myself up for discs from another supplier..
You know, I have had many, many cars over the years and fitted many replacement parts (Never cheap crap though) and usually bought from a auto accessory shop..
In the past I never seemed to have to be "precious" about going to the main dealership..
As is well known..Mercedes do NOT make the discs, so why should I use them when they wont back up the "quality" of their products.
The Following User Says Thank You to S.Speed For This Useful Post:
turbopete (23-05-2012)
Old 23-05-2012, 06:26 PM
I agree completely and there are other components that are questionable as well
Old 23-05-2012, 06:32 PM
LTD LTD is offline
Car: 2013 E220 CDi Coupe Sport
Bet you wouldn't have had this problem with an SL
Old 23-05-2012, 06:36 PM
Worse than that, I know
LTD (23-05-2012)
Old 23-05-2012, 06:45 PM
turbopete turbopete is online now
this makes me wonder, would the situation have still been the same if (as far as i know he isnt) Simon had been a time served, qualified mechanic, as i am? its not like the guy in the dealers could then say because they werent fitted by MB, they were improperly fitted! and to blame the pads is ridiculous! what will they think of next? sorry sir, your car is an auto and theyre more prone to warping discs due to the way people brake and then hold them on the footbrake meaning the area where the pads are cools more slowly (which is true in many cases) therefore we cant cover you under warranty due to it being an auto!
The Following 2 Users Say Thank You to turbopete For This Useful Post:
S.Speed (23-05-2012), television (23-05-2012)
[Spares] Command April 2013 Update discs E320Bert Spares for Sale and Wanted 5 15-08-2013 04:14 PM
NTG 2.5 Map update with 2012 discs - now done, but had a scare! pcman_jh Electrics, Vacuum, Ignition and ECU 1 27-05-2013 06:24 PM
2 sets of warped discs??? Is this possible?? muzbaz Suspension, Steering & Brakes 24 30-03-2013 10:12 PM
2 sets of warped AMG discs! grayb Suspension, Steering & Brakes 16 01-04-2011 08:15 PM
Warped discs? wowfunnyguy Suspension, Steering & Brakes 11 01-04-2010 07:01 PM
