Old 08-11-2014, 09:27 PM
rom1 rom1 is offline
Car: c220cdi coupe/2004
Default help with Bluetooth phone connection needed
I have one of these cradles in the arm rest and it works perfectly and has done for nearly 1 year with my iphone 5
http://www.commandonline.co.uk/Merce...tooth_HFP.html
My exacyt model is B6 787 5877
I am trying to link it to a samsung galaxy S5 it does find the phone and goes to the point of entering 4 digits on command unit then on the phone, but does not connect.
Does the same on Nexus 5 and iphone 6 and galaxy S3 mini.
spent a while in the car park at Car phone warehouse who concluded it only works with m iphone 5 as it is older phone
My question is. Is this a command unit issue, issue with the blue tooth cradle or something else?
Can the cradle be updated to include newer phones?
Any ideas on prices would be most welcome.
Also thinking of changing to an 2007 S class 320 cdi in a few months, am I right in thinking as t is pre 2009 I will still need and be able to use this cradle in the S class
I do not want to fit a parrot kit or anything else I want it be b exactly as it is now which is perfect but with the addition to be able to connect to newer phones.
Thans in advance for any help to resolve this.
Romil.
Old 08-11-2014, 09:40 PM
EmilysDad EmilysDad is offline
Car: R320 2007
Originally Posted by rom1 View Post
.... and goes to the point of entering 4 digits on.....
4 digits? Mine is 5 digits ie 62872 (ie MB USA on an older style phone that has letters too) mine is the newer B67880000 version but the MB salesman told me the code as I bought the car. My phone is a S3mini
Old 08-11-2014, 09:48 PM
Deffo only asks for 4 digits, pic of my cradle attached, even connection to iphone 5 used 4 digit pairing code
Name:	mb bt cradle .jpg
Old 08-11-2014, 10:25 PM
whitenemesis's Avatar
whitenemesis whitenemesis is offline
Car: CLS55 AMG '05
My guess is the software in the cradle can't handle the newer phones. Not sure if it's updatable, guys at Comand could advise.
Personally I'd ditch it for the ViseeO MB4
CLS55 AMG
C270 CDI - Gone but not Forgotten
Old 08-11-2014, 10:34 PM
Car: R320 2007
I'll see if my daughter's S5 will pair up with my car when see her next
Old 09-11-2014, 04:27 PM
Car: R320 2007
Just tried my daughter's S5 with my bluetooth hpf B67880000 and it paired up OK and dialled my mobile with no problems. (my radio isn't Comand though)
Old 09-11-2014, 09:52 PM
Early signs point towards an out dated cradle as 3 of the newer phonees will not connect, however older models are fine. Going to check if it can be updated otherwise will be going for ViseeO MB4 which is update-able by the user to cover newer phones.
Thank you for checking and everyone's input, will update once i can confirm if it can be updated or needs upgrading.
The Following User Says Thank You to rom1 For This Useful Post:
whitenemesis (09-11-2014)
Old 10-11-2014, 07:13 PM
Update: Spoke to command online today, my cradle can not be updated advised to go for
ViseeO MB-4.
Does anyone know if it will work in 2007 S class, as I will be changing soon and want to make sure I can use it, otherwise it is a pointless purchase just for a few months of use?
Old 23-03-2015, 11:26 PM
meintheuk1 meintheuk1 is offline
Car: 2004 E320
I had a nightmare trying to connect my galaxy s4 to my SAP V2. But eventually it worked and now seems to work fine, really pleased as I bought mine really cheap off eBay. : ) happy to answer any questions to help if I can
Old 23-03-2015, 11:57 PM
I purchased the viseeo mb4 cradle, worked straight away, bit tricky to import phone book, but worked it out. Has been working great with no issues.
whitenemesis (24-03-2015)
W204 blue tooth phone intermittent connection voyseyboy0 Electrics, Vacuum, Ignition and ECU 1 24-12-2012 02:50 PM
Bluetooth Phone SUNNY101 Electrics, Vacuum, Ignition and ECU 10 12-07-2012 04:21 PM
Bluetooth phone CLS 2006 raymerc Electrics, Vacuum, Ignition and ECU 2 15-07-2010 09:20 PM
FS: ViseeO MBU1000 UHI Bluetooth Adaptor Ian J Spares for Sale and Wanted 3 24-09-2008 07:15 AM
Bluetooth SAP V2 Cradle billy_whizz Spares for Sale and Wanted 1 29-08-2008 10:33 PM
