Old 02-12-2016, 10:15 AM
Little Phil Little Phil is offline
Car: R320L CDi 2007
Default Convenience Functions. Seat & Steering wheel
I have W251 (R320CDI(L).
Was trying to set seat + steering wheel function via convenience settings on steering wheel buttons.
I can see menu
Easy entry (off)
Steering wheel
Steering wheel + Seat.
I can highlight each function by using + or - minus buttons on the wheel.
Is that it? you just highlight the function? Is there a way to activate them?
I know the seat & steering wheel function works. Ever since I had the car, only the steering wheel lifted when I switched off, but recently when the car went into garage to replace leaking rear air bag, both the seat and wheel started working.
It went in to garage again to replace heater fan & a new battery, and now only the steering wheel lifts.
I cant seem to switch the seat & wheel function back on even though I can see it in the settings/convenience menu.
Am I missing something?
Any help appreciated
Phil
Old 02-12-2016, 02:46 PM
It is when they are highlighted that they function and active,,yes confusing at first but it does sink in.
Little Phil (02-12-2016)
Old 02-12-2016, 04:41 PM
Car: R320L CDi 2007
Huh!
The function is highlighted, but it doesn't seem to be working.... Even though the function did work for only 3/4 weeks out of my 7 year ownership of the vehicle, I miss it!
Any ideas?
Old 02-12-2016, 04:43 PM
Is there not a + and - to chose the options highlighted.
Old 02-12-2016, 05:12 PM
BillyBoy BillyBoy is offline
Car: GL420 CDI
Have the garage moved the seat? The seat element only works if the seat is forward past a certain point. Try moving the seat forward a few inches and see if it then moves back on opening the door.
Cheers,
Bill
X164 GL420 CDi
Audi Allroad (briefly); W212 E250 CDi Estate; W220 S320 CDi; W210 E320 CDi Estate
Ford Scorpio 24v Cosworth Estate; Ford Mondeo 2.0 Ghia X Hatch Auto; Ford Granada Scorpio 2.9i Auto; Ford Granada 2.0 Ghia Auto; Ford Sierra 1.8GL Estate; Ford Cortina 2.0 Ghia Auto; Ford Cortina 1.6 L; Vauxhall Chevette
The Following User Says Thank You to BillyBoy For This Useful Post:
Old 02-12-2016, 07:23 PM
Have you re memorized the seat settings, if not memorized it cannot work.
As Billy boy the function only works with the seat memorized more than way forward.
This whole function can get lost, and STAR needed to re set it all.
Old 03-12-2016, 11:13 AM
Car: R320L CDi 2007
Well, I am a "short arse" so the seat will deffo be more than halfway forward... and I did re memorise my seat function when I collected the car from the garage...
The only think I can think to do now is to move the seats back & forward, memorise seat positions and see if it works that way...
As I said, the function never worked for 7 years, and when it came back from garage 4 weeks ago, it was!
Whilst the garage I use doesn't have star, they did mention using their own code reader when diagnosing rear air bag... and when it came back the function was working.... this time, they used the code reader when trying to diagnose PDC fault... and they also used their code reader when diagnosing the heater fault... so I do think its something to with resetting & use of code reader...
Old 04-12-2016, 11:06 AM
Car: R320L CDi 2007
Default Well, I got it to work!
It IS to do with the memory function after all!
I moved seat back as far as it would go & stored the new position in the seat memory, then moved it back to my original position (Didn't store it)
Now, when I take the key out, seat moves back to the stored memory position & steering wheel raises.
Put key back in and seat then moves forward to my normal driving position & steering wheel lowers.
Switch off again, and seat moves back!
Its counter intuitive, but I'm happy now to have the function restored!
The Following User Says Thank You to Little Phil For This Useful Post:
BillyBoy (04-12-2016)
Old 04-12-2016, 01:17 PM
Pleased it was only the memory and all fine now.
Penta wheel rim bolt seat type. parkman Bodywork, Tyres, Wheels & Trim 7 06-09-2016 07:19 AM
Memory seat / steering wheel Robg45 Electrics, Vacuum, Ignition and ECU 3 21-03-2015 01:05 PM
Steering wheel out after bush replacement rx6180 Suspension, Steering & Brakes 2 14-01-2012 01:41 PM
2000 W208 multi function steering wheel controls for eonon stereo ontheball247 Electrics, Vacuum, Ignition and ECU 3 07-11-2011 12:02 PM
W124 steering wheel audio controls The Crooner Electrics, Vacuum, Ignition and ECU 5 23-07-2010 10:19 PM
