Old 28-09-2008, 09:36 PM
Adrianh1 Adrianh1 is offline
Default Glow plug light - comes on when engine hot 190D 2.5
A year ago I had all five glow plugs renewed with new Beru glow plugs. The car starts well and runs smoothly in all conditions. However in the last 6 months the glow plug warning light has a habit of coming on when the engine gets very hot, typically when idling in traffic. It will then extinguish after a few seconds. There is never a problem with starting the engine or with the engine running. I'm wondering if it might be a faulty relay, as I'm pretty sure the fault can't be with the glow plugs themselves, given how well the car starts and runs.
Any ideas?
Many thanks
Adrian
Old 29-09-2008, 11:53 AM
wireman wireman is offline
Car: nice 201 2.5D 1993 & very nice 129 SL500 1994
I have not seen this one before, but would aggree and suspect the relay unit. There is only the relay and a temp sensor in the head which would be able cause the lamp to illuminate, the temp sensor adjusts the time that the lamp and plugs glow for.
Open up the relay box and examine it for poor soldered joints on the PC board, it can be difficult to see but it might just be one solder joint becoming cracked/dry.
Old 30-09-2008, 12:54 PM
Thanks Wireman, I'll take another look at the relays here. Will report back in due course.
ADrian
How to - Repairing the Glow Plug Relay on a W203 220CDI Dunkuk Electrics, Vacuum, Ignition and ECU 13 08-05-2016 08:59 AM
w202 glow plug light stays on. 1998 c250 jgs600 Engine, Drivetrain, Fuel and Exhaust 7 25-06-2014 07:57 PM
Sprinter 310d Glow plug light Cnics Engine, Drivetrain, Fuel and Exhaust 3 14-11-2009 07:46 PM
190D Glow Plug Light silo Engine, Drivetrain, Fuel and Exhaust 1 10-12-2007 05:00 PM
Sprinter Glow plug light stays on repodave Electrics, Vacuum, Ignition and ECU 0 25-11-2007 03:53 PM
