Old 23-07-2009, 11:51 PM
omegav6 omegav6 is offline
Angry Help please ML 270 cdi black smoking really bad
Hi all Iím wondering if someone can give me advice on what to try next, Iím getting frustrated with this now the car is smoking thick black smoke when you put your foot down hard and it doesnít stop when you let your foot off a bit. If you was three cars behind me you would think it had gone dark itís that bad, the performance donít seem that bad but i donít drive the car that much the Mrs drives it. Iíve tried giving it a good long hard run to clear it to no avail. The injectors have been re seated and new bolts and washers used, all filters are new and the maf has been cleaned. The car has covered 100k which i donít believe is a lot for this engine. Any help or advice on what to try next will be greatly received
I would also like to thank Kebo57 for all his help with the other problems ive had with the car
Old 24-07-2009, 06:41 AM
5pares 5pares is offline
Car: E320cdi
Could be a turbo problem if youve check all the simple stuff,hoses, injectors etc.
www.suffolkautoservices.com
Old 24-07-2009, 07:16 AM
The turbo seems to be working fine and when the injectors where re seated they looked in vgc thanks for the reply
Old 24-07-2009, 07:27 AM
teddycatkin's Avatar
teddycatkin teddycatkin is offline
Car: W107-SL W124-220te W123-230e W201 2.0
Usually Turbo blown ?--the smoke will be oil in the exhaust.
Needs a diagnostic plug in to confirm the problem.
Old 24-07-2009, 07:28 AM
BlackC55's Avatar
BlackC55 BlackC55 is offline
Car: C43
I suspect a split boost pipe or intercooler.
www.PrestigeCarService.co.uk email. info@prestigecarservice.co.uk
Mercedes specialist.(Portsmouth, Horndean just off the A3) Ask me anything! 02392 570 123
Old 24-07-2009, 08:48 AM
ive always thought that engine oil smoke was blue ish and derv smoke was black am i wrong in thinking this
Old 24-07-2009, 09:14 AM
star's Avatar
star star is offline
Car: Smart + others :)
+1, and they do take some clearing if pottered around.
Star Motor Service Ltd
Mercedes Specialist In Reading
0118 9462750
www.Starmotorservices.com
www.Starmotorservices.co.uk
Old 24-07-2009, 09:25 AM
it don't really potter around she does drive it hard but its all town work no m ways its had a good 150mile m way run now and problem still there ive just spoke to a fried of mine and hes give me a number for someone who has a machine to plug into the car and see if there is anything showing up but there have been no lights on on thes dash will this matter
Old 28-07-2009, 11:15 AM
stumo's Avatar
stumo stumo is offline
Car: ML270CDI 2002 facelift| Sprinter 316CDI 2003 LWB
I reckon I know what it is...
I forget the technical term for them, but this engine has these flaps in the inlet manifold, they are there to help with engine braking etc. They are driven electronically, and they have been known to fail.
The Following User Says Thank You to stumo For This Useful Post:
anees (25-08-2010)
Old 28-07-2009, 11:08 PM
oigle's Avatar
oigle oigle is offline
Car: Currently 2003 ML270. 2012 Nissan Maxima 250SL.
You said you had cleaned your MAF. That doesn't mean it is OK. It is the main article that gives you your air/fuel mixture. I'd be inclined to check it properly.
2003 update ML270CDI
Mercedes C63 AMG Black Edition Conversion ProjexDesignUk Projex Design UK 2 18-06-2013 09:26 AM
ML 270 cdi injector problem elafs Engine, Drivetrain, Fuel and Exhaust 43 13-12-2012 01:25 PM
ML 270 CDi Smoking Duncan.ml Engine, Drivetrain, Fuel and Exhaust 6 09-11-2007 12:31 PM
Smoking E320 CDI simonxxx Engine, Drivetrain, Fuel and Exhaust 13 08-09-2006 06:11 PM
C Klass 270 CDI (w203) Lack of power and smoking liteuser Engine, Drivetrain, Fuel and Exhaust 29 07-09-2006 10:31 PM
