Mercedes-Benz Owners' Forums
Reply
Thread Tools Display Modes
  #1
Old 11-01-2017, 09:05 AM
Fotherm Fotherm is offline
Junior Member
Car: C Class / 2006/ 3000
Default Automatic Gear Change
Grateful if anyone could advise on the recent problem my C320 has developed - occassionally the car will not go into the next gear at around 50 mph. If I switch off the engine the problem is resolved. Any advice welcomed
  #2
Old 11-01-2017, 10:17 AM
Flyinspanner Flyinspanner is offline
Car: CL500 -W215, A140-W168
Default
How many miles has it done?
Is the transmission fluid at correct level?
How does fluid look? (Hopefully cherry red, sweet smelling)
If brownish or smells 'burnt' then you may well need a fluid change (has it ever been done in the past?)
If looks n smells ok, then get a STAR diagnosis.
If it feels sluggish and won't change up or down, (have you tried 'manually'- tapping selector sideways) then it may be the speed sensor on the gearbox electric 'plate' - it would be around 400 at an Indy inc trans fluid & filter.
__________________
Stick back, houses small.....stick fwd, houses big!
  #3
Old 11-01-2017, 12:24 PM
umblecumbuz umblecumbuz is offline
Car: S204 cdi, C220cdi 2005. C 270cdi (gone and regretted), SLK 3.2 (ditto), other non-Merc machines
Default
Check fluid level before doing anything elee.
If it hasn't been regularly serviced, this is the obvious first step.
Umble
  #4
Old 12-01-2017, 09:32 AM
Steve@Avantgarde Steve@Avantgarde is offline
Car: Mercedes-Benz C32AMG and SLR Coupe 2005.
Default
Valve in the valve body is sticking or the speed sensor on the TCU is filthy so it cannot read a permissible speed ratio.
You can try removing it, cleaning it and flushing the ATF, if it still happens after that then a new TCU will be required.
__________________
Avantgarde Automotive, Unit 14 Hither Green Trading Estate, Clevedon, North Somerset, BS21 6XU
01275 217270/07967 042960
https://twitter.com/AvantgardeMB
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How do I change gears manually on my 2008 mercedes c class automatic? geek84 General Mercedes-Benz Related Discussion 27 17-07-2015 03:09 PM
Seems to stick in gear and won't change..?? Jamboo Engine, Drivetrain, Fuel and Exhaust 24 01-03-2012 09:35 PM
automatic gear box oil change nrg220 Engine, Drivetrain, Fuel and Exhaust 18 08-01-2012 01:52 PM
E280cdi 2006 Gear Change Problem Oneilly Engine, Drivetrain, Fuel and Exhaust 9 19-12-2011 11:22 AM
C230 sport Kompressor gear change problem monumen Engine, Drivetrain, Fuel and Exhaust 27 23-10-2009 06:15 PM
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
