Old 11-01-2017, 04:05 PM
G style G style is offline
Car: S Class 2006 320CDI
Default W221 back end dropped right down onto tyres
Hi all,
I require help with my s class w221 came out to find the back end on the tyres can not use car now......I have checked it with my icarsoft and its given me a code of 5286 but can not fine out what that is nor what it has do with the back end as what i have found with that code is front suspension problems .....i have checked the fuses and the relay...but not sure how to test the pump as i can not get it to run and even pressing the rise button dose nothing....I have inpluged the compressor and tryed to get a reading but im guessing that it will only read something when it reqiures the pump to activate and seeing as i can not do that i stuck at this point. Any info would be greatly appreciated.
Thanks.
Old 11-01-2017, 05:03 PM
Craiglxviii Craiglxviii is offline
OK firstly what iCarsoft do you have?
It sounds as though the pump has failed and the rear valve block lock valves have stuck open.
Old 11-01-2017, 05:08 PM
Its an i980.
OK so ignore the automatic diagnoses menu and go into manual. Navigate to the ABC menu and scroll down to look at system pressure. What is the reading?
Old 11-01-2017, 05:10 PM
I will go and look now mate give me a few mins.
DREAMER NO2's Avatar
DREAMER NO2 DREAMER NO2 is offline
Car: W124 2.6E M103
Well i would get a good trolly jack and axle stands .Jack it up on the rear end jacking points, and put axle stand under the body jacking locations .So you can take the pressure off the rear suspension ,so no more damage can happen.Dont jack it up to high ,just to a normal possition..But i would say that its down on the bump stops and wont go any more ,May be its just the pump not working .
Old 11-01-2017, 05:13 PM
There are no bump stops on ABC struts... they're called "wheelarch liners"
Old 11-01-2017, 05:20 PM
Right mate sat in car now and im in diagnose mode. Into suspention and actual values then what do i do sorry for being a dum ass but im new to these readers lol.
Old 11-01-2017, 05:26 PM
Can not seem to find what you asked for mate?
Old 11-01-2017, 05:31 PM
Are you in "Manual" mode? Do not go into "Diagnose" as the reader will just act generically. You need to choose your specific car moderl, engine type and then navigate down until you find the ABC option.
Can I take fitted tyres back? Kylinski Motoring Related Discussion 30 10-08-2013 10:21 AM
Noisy Back End on 300TE 1988 mark0803 Engine, Drivetrain, Fuel and Exhaust 3 23-11-2006 12:02 AM
