  #21
Old 11-01-2017, 05:42 PM
Craiglxviii Craiglxviii is offline
Originally Posted by G style View Post
Right i have found a menu which states 158 left front level 10mm 161 right front level 3mm 164 rear level 127mm and 166 pressure at pressure sensor 0 bar. Does any of that help mate cause kooks to me that the pump is not working at all?
Pump has failed most likely; have you noticed poor response recently while driving?
With the engine on, locate the pump. There is a union that comes out of it with a line that leads to the ABC fluid reservoir- this is the pressure regulating valve. Try giving it a (VERY GENTLE!) tap with a soft faced mallet, it may open it.
Otherwise it's flatbed to indy time I'm afraid.
  #22
Old 11-01-2017, 05:44 PM
bembo449 bembo449 is offline
Car: 216 5.5 v8 , alfa GT , saab aero vert
so if yu start the car now , you should see a reading and the pump should kick in which you should hear
The Following User Says Thank You to bembo449 For This Useful Post:
Craiglxviii (11-01-2017)
  #23
Old 11-01-2017, 05:45 PM
Sorry to say it mate but im glad im not the only one.... was yours the pump that had gone?
Pump (twice...), strut, lines and valve block all needed replacing or stripping and rebuilding.
If your rear wheels have sunk that low, your valve block will also be gunked up; it will need stripping down, cleaning out and rebuilding. I have the correct O-rings in stock if this is the case.
  #24
G style G style is offline
Car: S Class 2006 320CDI
I have already got under the front and found the pump mate.....I mite just order a new pump and fit it. I have left off all the engine trays for now knowing im going to be revisting it lol. Where is the level sensors on the rear do you know mate?
  #25
Old 11-01-2017, 05:46 PM
EmilysDad EmilysDad is offline
Car: R320 2007
Told you before your a jinx to me fella lol. Happy new year mate
Happy New Year Lee
I only mentioned your SBC brakes ......
  #26
Old 11-01-2017, 05:47 PM
I have no sound from the pump and no reading.
  #27
is it no worth checking the larger fuses to see if ones blown ??
  #28
Level sensors are on the struts as I understand it. Pressure sensors on the front and rear valve blocks for the 221.
Reconditioned pumps for the 220/215/230 are 480 from MB (12 mth warranty)- I do not know if they will fit the 221/216/231 though so it will pay to check. The pumps have come down significantly in price over the last two years.
  #29
Old 11-01-2017, 05:48 PM
It is indeed, it sounds odd that the pump has just gone, usually there will be indications, white warnings and odd activity (including a pretty obvious noise!) before it fails completely.
  #30
Is this hard to do and where do i find the valve block mate......Again sorry for all the questions.
Can I take fitted tyres back? Kylinski Motoring Related Discussion 30 10-08-2013 10:21 AM
Noisy Back End on 300TE 1988 mark0803 Engine, Drivetrain, Fuel and Exhaust 3 23-11-2006 12:02 AM
