  #31
Old 11-01-2017, 04:49 PM
G style G style is offline
Car: S Class 2006 320CDI
Originally Posted by bembo449 View Post
is it no worth checking the larger fuses to see if ones blown ??
All done mate.
  #32
Old 11-01-2017, 04:50 PM
EmilysDad EmilysDad is online now
Car: R320 2007
Originally Posted by Craiglxviii View Post
Reconditioned pumps for the 220/215/230 are 480 from MB (12 mth warranty)- ....
That sounds almost reasonably priced if it's from MB
  #33
Old 11-01-2017, 04:51 PM
Craiglxviii Craiglxviii is offline
Originally Posted by G style View Post
Is this hard to do and where do i find the valve block mate......Again sorry for all the questions.
Not hard but just time consuming. You will need to make yourself a clean area- like surgically clean, no dust or dirt- to break down the valves, remove O-rings, scrub the shuttle bodies clean then rebuild it all.
Valve block is located on the body next to the rear axle. Aluminium block about 8 x 6 x 4" with 4 valve bodies poking out of it, 2 lines leading in and 2 lines leading out (HP in, LP out and one circuit to each rear wheel).
  #34
Yes I was astonished too as it's almost exactly the same as the ones from eBay.
  #35
Old 11-01-2017, 04:53 PM
bembo449 bembo449 is offline
Car: 216 5.5 v8 , saab aero vert, kia sorento 4x4
All done mate.
ok but I had this issue on my granddads S class and it wasn't the fuse for the pump that had blown , cant remember which one it was now but I replaced it and 30 seconds later it started to rise up , it was in the big fuse bow on the drivers side
  #36
Old 11-01-2017, 04:54 PM
DREAMER NO2's Avatar
DREAMER NO2 DREAMER NO2 is offline
Car: W124 2.6E M103
G STYLE I am still here .Can you go in to Google Search .
Then in the search box put this in -
Mercedes W212 320 cdi 2006 Body Down on the rear wheels . And the part to read is from MB Medic All about this and how to find more ways to check it .
The Following User Says Thank You to DREAMER NO2 For This Useful Post:
bembo449 (11-01-2017)
  #37
Old 11-01-2017, 04:55 PM
The 212 doesn't have ABC, that'll be Airmatic which is totally different.
  #38
Old 11-01-2017, 04:59 PM
Car: W124 2.6E M103
Glad you are around ! And they do have Airmatic .
  #39
Old 11-01-2017, 05:01 PM
Car: W124 2.6E M103
I may be wrong but do that Googe search. Then kick me after..
  #40
Old 11-01-2017, 05:02 PM
Air suspension- says quite clearly.
Right, bend over, this is going to hurt you a lot more than it will me...
The Following User Says Thank You to Craiglxviii For This Useful Post:
G style (11-01-2017)
Can I take fitted tyres back? Kylinski Motoring Related Discussion 30 10-08-2013 10:21 AM
Noisy Back End on 300TE 1988 mark0803 Engine, Drivetrain, Fuel and Exhaust 3 22-11-2006 11:02 PM
