Old 18-12-2011, 06:56 PM
Oneilly Oneilly is offline
Car: E Class 280 CDI 2006
Default E280cdi 2006 Gear Change Problem
Hi All, today I experienced a problem, I had to accelerate hard to avoid an accident, but when the automatic gear box dropped down a gear the car juddered and I had to back off the trottle, the car then woundn't change gear but also woundn't pick up speed, I had to pull over and restart the car, all was then back to normal.
Any ideas what this maybe?
Old 18-12-2011, 06:58 PM
Cole@MBS's Avatar
Cole@MBS Cole@MBS is offline
Car: 124 300 CE 24 Coupe, 209 240 CLK
Could be the start of the electric plate going down, might be a idea to get the fault codes read, see if it has stored something.......
M.B.S
Mercedes Benz Specialist
Star Diagnostics / Servicing, Brakes, Repairs
Woolston, Southampton. Tel: 02380 445820
Old 18-12-2011, 07:04 PM
Excuse my ignorance but what's the electric plate?
Old 18-12-2011, 07:07 PM
Cole@MBS's Avatar
Plate with all the electric solonids on it mounted inside the box itself........
M.B.S
The Following User Says Thank You to Cole@MBS For This Useful Post:
Oneilly (18-12-2011)
Old 18-12-2011, 07:47 PM
I just took it out and after many attempts got it to repeat it, dosen't do it every time and dosen't do it at all in sport mode!
Old 19-12-2011, 08:39 AM
Alex Crow's Avatar
Car: W169, W124, w202, W203, KTM 250 EXC, VW T25 camper and a Polo in a pear tree
Could this be a 'KID' mode problem?
Not seen one doing this as yet, but have heard it is becoming an issue - something to do with the TC external control?
Apparently they only do it in 'E' and are OK in 'S'.
ALEX CROW - Independent MERCEDES-BENZ Specialists
Old 19-12-2011, 09:17 AM
Thanks for your reply, does this sound expensive?
Old 19-12-2011, 09:44 AM
Why not just use the S setting, MB recommend this I think in the handbooks on most
Old 19-12-2011, 10:21 AM
Yeah, think i may just do that!
Old 19-12-2011, 10:22 AM
There really is no difference in economy by not using it,,its a well proven thing
Oneilly (19-12-2011)
C200k gear slip after gear oil change hawkeye Engine, Drivetrain, Fuel and Exhaust 2 19-03-2010 11:12 PM
Whining/Vibration on gear change chookdoo27 Engine, Drivetrain, Fuel and Exhaust 12 22-07-2009 09:05 AM
Gear change problem on my 1996-Manual-C230 MercMart0802 Engine, Drivetrain, Fuel and Exhaust 12 23-06-2009 07:28 AM
bad gear change panatukan Engine, Drivetrain, Fuel and Exhaust 5 30-04-2009 03:48 PM
Gear change problem marvinwright Engine, Drivetrain, Fuel and Exhaust 0 17-11-2007 12:35 PM
