Old 15-10-2012, 06:49 PM
ghmd ghmd is offline
Car: ML320
Default ML320 ECU random misfire!!!
Please help, my W reg ML320 is badly misfiring! It has been going on for months, I pull away and it goes into limp mode. I turn it off and the problem sometimes clears. On over-taking, it sometimes loses powere and this morning i nearly had an accident. We replaced the oxygen sensor and the problem still happens. I took it to the garage and the diagnostic was 'ECU random misfire'!
We replaced the MAF sensor and it improved for a while but now it is bad again. It is worse in damp and cold conditions. It is driving me nuts!! Please help!
Old 15-10-2012, 06:51 PM
WG M-B WG M-B is offline
Car: ML 55 AND OTHERS
Can it not go on star to be checked by somebody???
Old 15-10-2012, 07:48 PM
jibcl500's Avatar
jibcl500 jibcl500 is offline
Car: CL500,ML320,SLK230K,Smart CDI
Could be anything but unless it goes on star diagnostics your p!$$ing in the wind sunshine.
Coil packs?
plugs?
HT leads?
cats blocked?
O2 sensors?
Any dash lights?
jib
00 SLK 230 Komp
95 C140 CL500
00 ML320
59 Smart CDI
89 T1 208D Camper
The Following User Says Thank You to jibcl500 For This Useful Post:
ghmd (31-10-2012)
Old 15-10-2012, 08:11 PM
Very well put !!!
The Following User Says Thank You to WG M-B For This Useful Post:
jibcl500 (16-10-2012)
Old 16-10-2012, 06:10 PM
jibcl500's Avatar
Your also not that far from me so if the ML can get here I can do a free yes free star diags for you, I also have a great many spare parts for the 320 so if we need something I should have it.
jib
00 SLK 230 Komp
95 C140 CL500
00 ML320
59 Smart CDI
89 T1 208D Camper
ghmd (31-10-2012)
Old 31-10-2012, 02:20 PM
Car: ML320
Where are you? What is star? No dash lights
Old 31-10-2012, 02:55 PM
jibcl500's Avatar
CB6 3UL
Star diagnostics
jib
00 SLK 230 Komp
95 C140 CL500
00 ML320
59 Smart CDI
89 T1 208D Camper
Tags
ecu random misfire ml320
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
