Old 05-11-2012, 04:25 PM
slk32uk slk32uk is offline
Car: slk32 2002
Default SLK32 ic pump relay question
I just bought a SLK32 and noticed a marked drop in performance when warmed up that comes and goes. From reading threads it seemed probable the IC cooling pump had gone, indeed the 5a fuse had blown. Replaced the pump with a bosch uprated pump and the fuse but still no change. Fairly sure it is not getting any power. Read elsewhere that the relay often needs changing at the same time. A MB dealership were pretty unsure what relay it was but guessed it was a general engine management relay at over 114 + vat. Needless to say they didnt have it in stock either.
Could anyone tell me where the actual relay is located? I would like to pull the relay and then get a part number and check it out.
any help much appreciated
W124 300E-24 Relay Types and Location jonclancy Electrics, Vacuum, Ignition and ECU 14 04-08-2013 03:02 PM
washer pump.. sam or relay foy65 Electrics, Vacuum, Ignition and ECU 0 05-05-2013 08:47 AM
HELP!!!Kickdown relay/Fuel pump relay? 1996bez280 General Mercedes-Benz Related Discussion 1 16-09-2008 06:01 PM
Fuel pump relay question ..Help Please!! Red Rolo Electrics, Vacuum, Ignition and ECU 3 17-07-2008 07:55 PM
1974 450 slc fuel pump relay question mtd1960 Electrics, Vacuum, Ignition and ECU 0 05-09-2006 11:52 PM
