Old 02-04-2007, 08:43 PM
anyweb's Avatar
anyweb anyweb is offline
Default repairing broken W202 Key fob.
hi all, I'm posting this incase any of you have a similar problem, sure saved me some bucks and only took an hour or so to fix.
This how-to is mirrored here > http://www.niallbrady.com/mycar/c220/fixkey.html
Problem:-
* key won't open the car
* key LED won't light even with known good batteries
* chance that you may have dropped the key recently
Solution:-
In my case, the solution to the problem became evident when I took the key apart (it should prise apart quite easily, if not use gentle force), as a piece of it fell to the floor when I got the two halves open. The piece that fell on the floor was an electronic switch which had become loose from its 4 soldered leg joints.
So what do you need to accomplish this ?
* steady hand
* bright light
* a magnifying glass to see the solder joints etc..
* a soldering iron
* some solder wire
(see below)
Here is my broken key in it's disassembled state.
You can see the switch is not attached to the circuit board, and thus, the key's infrared functions cannot work.
I examined the detached switch with a magnifying glass and could see the legs were bent so I re-arrangfed them gently to be more in line with the 4 contacts on the circuit board (be gentle, if any of the legs snap off you are going to find it VERY hard to fix as they are so small).
I then aligned the switch to it's mating points on the circuit board, at this point, I held it very tightly against the board and had my soldering iron heated up for the next stage, soldering.
Once correctly aligned I carefully got a blob of solder on the end of the soldering iron and 'touched' it briefly to each of the 4 legs in turn until they clearly had solder in place. Be careful with the soldering iron, you could end up getting solder on any of the other contact areas around the switch and that wouldnt be a good idea as there are quite a few 'lines' running around it.
Here's what they looked like after the soldering process
Finally I had to reassemble the key at this point you can put the two batteries back in and you should see the familiar LED light up after a few seconds of pressing *SUCCESS*
Please note:- when you have the key all back together again, you may notice that it doesnt 'flick out' as it used to, this is simple to fix, open the key again in two halves and 'wind' the key around its centre point ONE FULL TURN in the direction of force, then place the two halves back together again.
One last note, after doing this job you'll have to RESYNC the key to your car, to do so, do as follows,
press the button on the key while pointing it at the rear view mirror then insert the key in the ignition and turn it so that all the dash board lights light up, wait a few seconds then take it out of the ignition, press again and the GREEN or RED mirror led should light. If they both flash together at the same time then try again. If they continue to flash together then replace the batteries and try again, if they flash alternatly (red/green/red/green) then you may have some other problem like the car battery).
cheers
anyweb
I drive a 1995 W202 C220.
What a Great car !
I'm also lucky enough to have a 1966 W110.
The Following 2 Users Say Thank You to anyweb For This Useful Post:
lukejr (17-08-2009), pitch1 (17-02-2010)
Old 02-04-2007, 08:56 PM
Banned
Car: SL500 R230 with everything
What a genius you are with the brilliant photos and write up.
it is possible to put an elastic band around the whole thing to hold the switch in place while you tack the first leg of the switch to the PCB.
Tactile switches are available from all TV service centers if the legs are broken on the existing switch, they come in 3 types.
Congratulations Niall .
The Following 2 Users Say Thank You to television For This Useful Post:
Joeybagger (01-04-2010), One Driver (29-01-2010)
Old 02-04-2007, 09:06 PM
anyweb's Avatar
thanks malcolm, it sure was a relief when the key worked after the soldering job !
cheers
anyweb
What a Great car !
Old 02-04-2007, 09:09 PM
Banned
cheers
anyweb
2000kr of relief, the pics are a joy
Old 03-04-2007, 07:37 AM
Doyle's Avatar
Doyle Doyle is offline
i paid £120 for a new key a wee while back where was this guide then?!!!! lol
nice guide mate very helpful and ill give it a go on my other broken key.
1995 W202 Blue-Black C200 Sport
PimP WagoN
Old 11-04-2007, 08:15 PM
anyweb's Avatar
did it work on your broken key ?
cheers
anyweb
What a Great car !
Old 26-08-2007, 04:45 PM
lovedove13 lovedove13 is offline
Default Key fob repair..WORKED!
THANK YOU! One of my key fob cases opened easily and by following your instructions the repair is done and it works! The problem is I can't get the other fob case opened. I'm destroying the case just trying to pry it open. Is there a trick? If I can't get it open do you know where I can get an inexpensive replacement? I can't find one on Ebay. Thank you!
Old 26-08-2007, 06:05 PM
anyweb's Avatar
the previous owner may have glued it shut,
just use force around the visible edges and it will come apart eventually,
forget about ebay for replacements,
cheers
anyweb
What a Great car !
Old 30-09-2007, 08:04 PM
mhdgibbs mhdgibbs is offline
good description and very helpful both of my keys had this problem managed to bodge one back together so can use it as spare when ive bought new one from MB dealer
Old 30-09-2007, 09:53 PM
Banned
If you cannot close the case again,plumbers pipe solvent will glue it, do leave it overnight to set
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
