Old 06-10-2009, 11:01 PM
Bolide Bolide is offline
Car: BMW 525 Diesel Touring
Default Attention W124 E300 Diesel owners
Attention W124 E300 Diesel owners!
I think every E300 Diesel I've sold in the last 18-24 months has needed:
* new engine mounts
* new balljoints
If you own an E300 Diesel please replace the balljoints asap, assuming you've not had them done in the last five years, and please also budget to replace the engine mounts
Balljoints are "mission-critical" and new engine mounts make the car a lot nicer to drive & save wear & tear on the front prop doughnut
Nick Froome
www.w124.co.uk
Old 07-10-2009, 08:51 AM
Number_Cruncher Number_Cruncher is offline
Car: 1995 W124 E300D TE
I second the advice about W124 balljoints.
Owing to the way the joint is loaded by the coil spring AND owing to the way these ball joints tend to fail by becoming tight rather than loose many garages and MOT stations fail to detect a problem, even when they are in quite a dangerous condition.
The consequences of balljoint failure, at a minimum includes the cost of recovering the vehicle to somewhere it can be worked on, because it can't be driven or even towed in that state. Saving this recovery fee alone will go a long way towards paying for new joints to be fitted at the time and place of your choosing - not the car's!
The Following User Says Thank You to Number_Cruncher For This Useful Post:
television (07-10-2009)
Old 07-10-2009, 11:38 AM
wireman wireman is offline
Car: grotty 124 250D 1989 & nice 201 2.5D 1992
If you do the engine mounts don't buy the cheapo ones from GSF, they are not anywhere near the mark having much poorer vibration isolation than the genuine parts.
The Following 2 Users Say Thank You to wireman For This Useful Post:
SilverSaloon (11-03-2010), television (07-10-2009)
Old 07-10-2009, 01:11 PM
brianbrian's Avatar
brianbrian brianbrian is offline
Car: w124 250D, SL129-deisel
P.S. and don't for get g/box mount while your at it as its as cheap as chips. Hope this helps
Old 07-10-2009, 03:40 PM
roadhog's Avatar
roadhog roadhog is offline
Car: W124 300D
Good point, I've replaced my engine mounts and the ball joints but never thought to do the gearbox mount. Now added to my to-do list.
Old 14-12-2009, 07:42 PM
mb300d mb300d is offline
Car: e300d
Are the o/s and n/s mounts exactly the same part on a 95 e300d estate?
Old 14-12-2009, 07:52 PM
jibcl500's Avatar
jibcl500 jibcl500 is offline
Car: CL500,ML320,SLK230K,Smart CDI
Not just mounts but anything from GSF or Eurocar parts, sorry but I dont rate them and the only reason they sell mercedes parts is because they didnt meet mercedes specs!!!! And lets face it any company happy to sell mickey mouse air flow meters at £50 isnt worth dealing with.
jib
Old 14-12-2009, 08:16 PM
Car: e300d
jib
I tend to agree with you on most things but there are exceptions - such as ATE brakes at ECP and Fuchs oil at GSF. A lot of the "made in Germany" stuff to make you think it is OE std is inferior.
Old 14-12-2009, 08:17 PM
Car: e300d
Pls can you point me to the gearbox mount - where is it exactly? IS it oil filled as well?
Old 21-12-2009, 08:08 AM
The Crooner The Crooner is offline
Car: W124 1992 230TE
Its fastened to a cross member at the rear of the gear box.
I removed the cross member as access was easier.
Its a substantial rubber/metal component, butr not ouil filled as far as I could see.
If you have the right tools changing all three mounts is easy DIY
Buying a 124 and running it for the long term, providing its structurally sound, makes good sense financially, environmentally, and anally, if fit, finish, quality materials and engineering matter to you.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
