Old 19-05-2011, 02:15 PM
leigh69 leigh69 is offline
Car: SLK 230 1997
Default Slk 230 power problems
HI all,
About a month ago, i purchased a 1997 slk230 kompressor the car was working excellent til today, when i got on the bypass suddenly felt loss of power and the check engine light came on i put my foot down to pull away and it started to back fire, i lost gear selection it semmed to be stuck in 4th. would not even go into 1st manually. When i came to a stop the car was shaking then stalled. Just would not go faster than 40mph not sure if it was in limp mode???
Any ideas what it could be ????
Old 19-05-2011, 04:09 PM
Steve@Avantgarde Steve@Avantgarde is offline
Car: Mercedes-Benz C250 Sport Estate W202 & C220CDI Sport Coupe AMG
Sounds like MAF or Coil pack failure to me. A Star test would be the first place to start.
Avantgarde Automotive, Martock Business Park, Martock, Somerset, TA12 6HB
01935 829461/07917 177011
www.avantgarde-automotive.co.uk
The Following User Says Thank You to Steve@Avantgarde For This Useful Post:
leigh69 (19-05-2011)
Old 19-05-2011, 04:42 PM
moosehead's Avatar
moosehead moosehead is offline
Car: C230/2005/2.5L
I replaced the MAF on our SLK 2 years ago following loss of power and erratic gearchanges. It was the orignal unit as we've owned the car from almost new. If you take the MAF off you will find it might have 2 part numbers - MB and Bosch. Go to Eurocar parts and buy the Bosch unit. The unit was around £140-150. If you don't want to risk £150 get an indie to read the diagnostics with Star.
C230 V6 Avantgarde SE Estate
SLK230 Kompressor
The Following User Says Thank You to moosehead For This Useful Post:
Old 20-05-2011, 08:46 AM
Car: Not a BMW
worth cleaning the maf on this one, very prone to oiling, especially during hardish acceleration.
ALEX CROW - Independent MERCEDES-BENZ Specialists to the discerning.
Visit http://alexcrow.moonfruit.com/ or call 01449 258185 for more details.
The Following User Says Thank You to Alex Crow For This Useful Post:
leigh69 (20-05-2011)
Old 20-05-2011, 07:15 PM
moosehead's Avatar
Car: C230/2005/2.5L
I did try this with ours first of all (isopropyl cleaner) but it made no difference and didn't appear to be dirty / oily. I tried unplugging the MAF as well and the engine cut out.
SLK230 Kompressor
Old 20-05-2011, 09:24 PM
Car: Not a BMW
was it an early 111 engine with supercharger? these models are particularly prone to it.
Old 31-07-2011, 09:22 AM
dakudaman dakudaman is offline
Car: 1997 230SLK
Default Oil on MAF sensor
Where is the oil coming from? I also have oil on my MAF. The one on my vehicle has no mumbers so I bought a new Bosch unit, but have yet to install it due to I don't want to get it messed up with oil like the one that's on there now. So evey 2-3 weeks I just spray it down with MAF sensor cleaner. I would like to fix the problem of the oil source.
Any tips? Thanks
Old 31-07-2011, 03:44 PM
Car: Not a BMW
have a good read here...
http://forums.mercedesclub.org.uk/sh...ad.php?t=34036
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
