05 Vito Cd wiring guide help needed !
E-DESPATCH
Hi all, I've got a 05 109 Vito dual liner (six seats) wanted to add a couple of speaks to the exsisting fronts, the head unit has fade and balance for more speakers so I took head unit out and on the back is two blocks one with power, earth, etc and four speaker wire's for the fronts, then theres two earth looking wire's on the second block? wot are these for? also how / where do I put new speaker wire's in the block as I have no wiring diagram.
Cheers to all who reply
marnix
Becker Radio connector block
If this is the right one
Block 1= Power supply
Block 2= Speakers
Block 3= Connection for CD changer
In block 2
1[ 3[ 5[ 7[
2[ 4[ 6[ 8[
1= Right rear+ 5= Left front+
2= Right rear- 6= left front-
3= Right front+ 7= Left rear+
4= Right front- 8= left rear-
E
E-DESPATCH
thanks for the info but mine only has two blocks and the power and front speakers are on the same one? the second block has 2 earth like wire's in it.when I pulled tha block out it did'nt effect the sound? the unit is the standard single cd player.
E
E-DESPATCH
Sorry to Marnix saying it was the wrong one, after a closer inspection it was right and I now have 6" by 9" 's blasting in the back..... cheers
marnix
Glad to be able to help.
Very nice of you bothering to say "thanks".
Doesn't happen to often
All the Best
Marnix
Jay-lincs
Hi Marnix
Just wondered if you knew the pins configurations on the other 2 blocks. Ive got a audio 10 cd player in a 2004 vito 111 and am going to fit a parrot bluetooth kit which has audio mute for the radio Not sure till it comes what I need with regards to connecting to the radio but would help If I knew the wiring configurations.
Kind regards
Jay
