107 mercedes 500sl 1982 wiper problem
PeterWright
Hi
Any ideas the wipers dont work on my car?
The indicators and main beam work on the stork but no wipers.
I have a 450 haynes manuel and it says nothing at all about wipers apart from changing the blades.
I have checked all fuses all ok.
The car is running now but hasn't run for two years.
Regards
peter:confused:
meanie
Oxon
The connector block for the multifunction switch is down by the drivers knee.The cover can be removed making it easy to check for power coming out of it.
If there is power then bearing in mind the recent history of your car the chances are that the fault lies with the motor.
Was it parked outside for the last two years?
ChrisHeg
Isle of Man
500SL 1986 5litre CLK 320 2001 Avantgarde
Hi Was this ever resolved? My 86 has seized wipers, the motor works fine but not the mechanical bits. How do you release, lubricate or change the the mechanism?
I think there is a Haines book for your car, worth having for these jobs
Alex M Grieve
Broom, Warwickshire
Parrot of Doom did an illustrated post on how to lubricate the wiper mechanism of the 124 - I am sure that would answer your question.
http://forums.mercedesclub.org.uk/showpost.php?p=163567&postcount=1
Nothing like the same Alex
index.php
