Hi My son has a 97 P reg 108D with 147k. Recently it started dribbling oil from the drivers side rear corner of the cylinder head and has started blue smoking. Starts, runs and pulls ok as normal, no loss of water or oil in water and no water in oil.
I suspect head gasket has gone between combustion chamber, oil gallery and exterior of head joint, consequently on compression stroke is blowing oil and on downstroke is sucking oil in to combustion and hence smoking.
Does this sound feasible and how bad a job is replacing the gasket.
Further complication, 1 cylinder head stud was found to be broken flush with head joint at that rear (probable cause of gasket failure maybe?)
Any tips on how to get broken stud out.
Also any advice on what other secondhand more powerful powertrains would fit directly into this van, son would like a bit more oomph and the current gearbox is also pretty short on synchromesh.
Any help much appreciated.
Billy
Billy
