Chazchuzzlewitt
- Nov 30, 2004
- Location
- Dorchester
- W/S124 320TE Estate
typical... go to check & replace my rear brake pads and find out what was causing the sqealing I was getting... right-side outer pad was worn down almost to the bracking and the piston is stuck in the out position and doesn't want to budge... tried bleeding the moving it but it's still removing to give more than a tiny amount... any tips?!
