12 volt socket not working
jibcl500
Cambridgeshire
CL500,ML55,SLK280
All
w211 problem.
Having problems with a 12 volt socket, its where the front in dash ciggy lighter would be, fuse is on the drivers side panel, power going to the fuse 9.* volts but socket not working.
Am I looking in the wrong place or do I need to remove the ashtray ?
jib
Hi Jiles, was the fuse location taken from the chart with the car as the are several different layouts
jibcl500
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Malcolm
Yes taken from the chart.
jib
I have sent you the ashtray removal instructions so that you can check if there is a voltage on the rear
Dec
Ireland.
W202
The cigar lighter fuse may be shared with the glove box light or some other consumers, so if the are working then it wont be the fuse.
Dec
Tel: 020 8863 9233
