I seem to have a problem that has cropped up quite alot, after an oil change, using the usual 10/40 semi-synthetic oil, i have a noisey tappet, lasts on and off for a minute or so and then goes. Would another oil change with a slightly thinner oil help, as I have read on previous threads that the problem can cure itself in time, if this is the case how long should I leave it before changing the tappets?
