124 electrics
JACKLEE
hoddesdon herts
260 e saab 900 HONDA ACCORD
any help on instrument lighting heating controls electic window switches etc main lights on
roadhog
Sunny Norfolk
W124 300D x2, C124 300
What sort of help? If your instrument lights are dim/off with the lights switched on try turning the trip reset as that's where you adjust the brightness. Took me a while to find out as well.
PS: Hello and welcome. :)
Hello and welcome, as roadhog, turn the speedo re set knob a few times sharply
JACKLEE
hoddesdon herts
instrument lighting
HI HAVE TRIED DIMMER SWITCH SEVERAL TIMES CHECKED BULBS REMOVED SPEEDO CLEANED CONTROLS STILL NO JOY EVERY THING ELSE WORKING FINE APART FROM HEATED REAR WINDOW SWITCH WILL WORK SOMETIMES:confused: ANY HELP WILL BE APPRECIATED JACKLEE
So you have the instrument lights back now all working, and the only fault now that was not mentioned before is that the heated rear window switch does not work sometimes, or is it the back lighting that is not working sometimes
JACKLEE
hoddesdon herts
so you have the instrument lights back now all working, and the only fault now that was not mentioned before is that the heated rear window switch does not work sometimes, or is it the back lighting that is not working sometimes
hi no lights are working only speedo lights have tried dimmer switch still no lights mentioned heated rear window switch thought it might have been on same supply many thanks
JACKLEE
hoddesdon herts
Hi no lights working after several attempts at dimmer swich have checked all bulbs replaced with new still no lights on heater controls electric window swithes (all) etc
The only thing that I know then is to check the tiny red fuse on the rear of the cluster, rated at 1 amp
JACKLEE
hoddesdon herts
jacklee
Many thanks will try can you tell me where to look many thanks
You have to pull or push the cluster out, and it is on the rear
JACKLEE
hoddesdon herts
jacklee
HI MANY THANKS FOR REPLY BUT I CAN NOT FIND FUSE ANYWHERE ANY PICTURES PLEASE :confused:
The Crooner
Woodhall Spa Lincolnshire
2006 R320 cdi
You cabt see it until you have pulled out the cluster.
Its on the rear of the cluster, on the left hand side as you look at the front of the car.
You need to loosen the speedo cable, then remove it, and another large connector from the rear of the cluster.
I did it - cant be difficult then.
Tony
JACKLEE
hoddesdon herts
Jacklee
Sorry but cannot find pictures
JACKLEE
hoddesdon herts
  • #18
Jacklee
Many thanks mine is blue that i take it is the wrong one ( has a bulb) i wil purchase one from mercs and try that will inform you of results once again thank you very much paul
JACKLEE
hoddesdon herts
  • #19
jacklee
Hi malcolm fuse done the trick thankyou if you dont mind i have one more problem have no remote locking on car open by key the problem is that it only opens the drivers door all others have to be opened manually any advise please ps i can see movement passenger door rear left hand when key is in locked position thanks paul
