JohnG
- Apr 22, 2002
- Location
- UK
- SLK 200 (2001), CLC 1.8 (2011)
Hello all,
the car is an automatic 1.8 litre 190E (1991), 205,000 miles. On turning the starter key, the engine turns over reasonably well but is very sluggish to start although, with persistence, it will start. When it starts, it ticks over roughly and stops after about a minute. It seems to run as normal if my foot is on the accelerator but it lacks power when I attempt to drive it. This problem appeared suddenly and unexpectedly after the car had been left outside without being driven for several days.
Other things that might or might not be related. 1) the radiator is leaking. I suspect that this could be damage caused by the very rough swaying of the engine after the fault described above developed. There was no evidence of a leak beforehand. However, there is water in the cooling system - the leak is very recent. 2) About a week ago, the fuel gauge needle occasionally started to fall towards empty in an erratic and unpredictable manner before rising again to its correct postion. This behaviour lasted for a day or two and then appeared to sort itself out.
Any suggestions would be very welcome.
Regards
Regards
