O
olliecampbell
Hi All,
I've had a search and couldn't find anything related so here goes:
I've just replaced the rear pads, discs and brake lines (including the hard ones - god that was hard, corrosion-r-us!) on my 190E. I bled all the brakes, fronts included.
I now seem to have the 'brake fluid low/parking brake' light on all the time even though the handbrake is down/off.
The fluid level is topped up and I made sure it was when bleeding. The reservoir does look slightly strange though. If you're looking at it from the drivers side of the engine bay...the front half is up to the 'max' level but the rear of the reservoir is below the 'low' level. Should it be like this?
Thanks in advance.
Thanks in advance.
