Robert_2253
- Mar 23, 2006
Can anyone help me out ? My treasured 1988 190E 2.6 straight six petrol motor keeps momentarily cutting out just as though there is a broken wire in the low tension ignition circuit. The problem started 2 yrs ago, very occassional at first but has progressively worsened. The strange thing is that the problem gets worse the warmer the weather. When the outside air temperature is below freezing there is no problem at all and she goes like the wind. A warm spring afternoon, especially if the car has been parked in the sun, is an entirely different matter, and the car is virtually undriveable.
I've done the usual things including a full service at a Merc main agent garage but to no avail. The ignition switch has been changed, as has the fuel filter, valve guide oil seals, plugs, plug leads etc. Both the distributor and the ECU have been substituted without any improvement. During repeated visits to my local garage the wiring and fuse box connections have all been checked. The car recently passed an emissions control test without problem.
When the car does decide to run ok (on cooler days) it now feels a bit down on power at times with the economy meter further towards the red sector than usual, and at other times it gives a feel that it is only 'just' running.
The garage has now had the car for a month without success.
Any suggestions that anyone can give would be very much appreciated.
Thanks in advance. Robert.
