Greybeard
- Aug 18, 2007
- Location
- East Rudham
- 190E 1987 2.0 petrol+lpg
Hi All.
This is my first plea for help, but for one minute don't think it will be my last.
I've just acquired my first Merc, a 1989 190e, 2.0 auto, converted to lpg.
The latest in about a dozen cars that I've owned over the past 40 years, but the first with electric windows. In my case, the rear driver's side switch on the gear console is non-functional, as is the corresponding switch on the door (all others ok).
I've read through several posts about repairs to these, and I've just stripped out the switch on the console ( broken internal plastic moulding, which I've repaired, plus dirty contacts).
I'm now faced with the task of "re-setting"(?) some electronic gizmo that allows the whole shebang to operate correctly, entailing disconnecting the battery, holding down switches, and possibly performing some ancient Anglo-Saxon rite.
Having removed the two connectors beneath the console switches to remove it, neither windows on the driver's side now operate(others still ok).
If I press the driver's window switch for "up", I can hear a relay operate, but then the window is closed anyway. No sounds or action from the rear switch.
I think I now need someone to give me a brain-dead walk through the "re-setting" sequence.
I've no owners manual, and only a Haynes for an earlier model( - 1987) courtesy of the previous owner.
If someone could also tell me what the four-way switch at the upper end of the gear console is for, I should be most grateful.
Doesn't seem to operate an ejector seat or anything that I've noticed.
Regards
John
Regards
John
