Hi - I have a few things I need to do.
1. Does anyone know how to remove the headlight switch? There are no lights on and I would like to change the bulb(s)
2. Also, when I removed the undercover, I noticed a yellow wire with a connector on the end which isn't connected to anything - it doesn't look like it is anything to do with the headlight switch though as I can;t see where it would connect to??
3. The adjuster for the headlights does not work. Is this anything to do with the yellow wire? I think this is air controlled isn't it?
Thanks in advance.
Regards,
Mark
Thanks in advance.
Regards,
Mark
