190e heater control switch buggered?
theonewhosmokes
hello forum, have a 190e on a f plate, the heater control switch became stiff, forced slightly to turn off and know does not turn on the heating:sad: , is there a link broken?
q. can i take out the unit and service, if so do i completley remove the fascia
if not
were can i purchase a new unit or have 1 fitted live in bedfordshire if any one knows a good mechanic.
thanks in advance
T
theonewhosmokes
Resolved; 190e heater control switch buggered?
Thanks for the reply, Malcom.Thought id be shelling out for a new matrix:mad: Problem solved the blower heater switch broken, remedy new heater control unit (used) £10 + vat from www.mercman.net or :eek: £25 + vat new from merc parts of solihul. Remove fasica and refit. :D
Mech quoted me £45 per hour + parts, Diy Job saved a bit of cash, just awaiting delivery.
As you are a new member,you should make a note of this link
http://www.detali.ru/cat/oem_mb0.asp?TP=1
Just go to your car with the VIN numbers, and the whole car is there,useful when you can do it yourself. Pleased that you have solved the switch at a sensible price.
Malcolm
