drainaudio
Hi all,
Still trying to solve the slight bit of intermittent diff backlash I'm having.
George Fraser have gone through the driveline and say it's all good, they also say the diff is good. I however can't believe a backlash that has an audible metallic clunk to it is how MB designed this car.
I don't have any vibration in the driveline or diff/gearbox noise other that what I would consider normal compared to other cars.
The 190E will be changing smooth as pie up and down through the gears whether being driven soft or hard and then sudddely "clunk" diff backlash!! :Oops: What I have discovered 2day and maybe this sheds some light on the problem is the follwing: Level surface change from Park to D or R smooth no problem as you would expect. If the nose is pointing downhill and I change from Park to D, no problem but form Park to R there is an audible mettalic clunk and the car jumps a little. Same thing happens in the opposite situation Park to D if the nose is pointing uphill.
Would this not suggest some sort of play somewhere in the driveline?
Any help would be appreciated this is starting to drive me crazy!!
Thanks, Geoff.
Thanks, Geoff.
