190E How to seperate window regulator and motor
Stevie A
Scotland
I managed to find a new electric window motor (without the regulator) for my 190E.
I have taken the old regulator out complete with the motor still on. The motor is held onto the regulator by 3 cross headed screws, but one is impossible to get to without taking the regulator apart I presume. There is a large circlip type spring in the centre of the regulator - does this hold the regulator parts together? Or is it riveted together at the factory?
Has anyone swapped / changed the motor on a window regulator before?
Please advise.
Dec
Ireland.
W202
I’m not too familiar with the front mechanism but I think that the same principles apply, as with the rear mechanism, regarding the way the motor is connected to the lifting mechanism, See picture M and N here.
What is preventing the 1 fixing screws are coming out, it should be just a mater of separating the two parts, the will be a thigh fit so some wiggling may be required.
Is this your setup below. I don’t see any circlips in diagram.
http://www.detali.ru/cat/oem_mb2.asp?TP=1&F=201034&M=102%2E983&GA=722%2E410&GM=717%2E404&L=765%2E902&CT=F&cat=500&SID=82&SGR=405&SGN=12
http://www.detali.ru/cat/oem_mb2.asp?TP=1&F=201034&M=102%2E983&GA=722%2E410&GM=717%2E404&L=765%2E902&CT=F&cat=500&SID=72&SGR=045&SGN=03
Dec
brandwooddixon
Wolverhampton
S63 Coupe 2014
On the later E class the regulator motor is unscrewed where it is attached to the regulator and then rotated before it can be removed. See the DIY post.
Dec - your DIY would be a great addition on this forum.
You are right please Dec put your article in the DIY,,the one in the link
Dec
Ireland.
W202
It is there already, it’s a bit complicated, only part of it is in the DIY Bodywork section because I ran out of picture space when I originally posted it but there is a link in it to the full version on my free web space.
I see a similar Window Regulator DIY by Chris in the Electrical section so one of them is in the wrong place.
http://forums.mercedesclub.org.uk/forumdisplay.php?f=46
Dec
Dec
Can you ask a mod to sort it out please
Stevie A
Stevie A
Scotland
Thanks for replies. I've been away from home so hence delayed reply. The front mechanism is on a toothed cog system, not a cable. The links that Dec has provided show it on detail.ru. The second link shows what it looks like. I am going to take the regulator out again and see if I can separate the motor from it. Once I figure it out I will post.
I did think about rotating the motor to get access to the third screw but it was still impossible to get access to it. I did think also about drilling through the plate to get to the screw.
I have a question for Malcolm - the old window motor still works when not connected to the glass, and will move the glass only a little when connected. I have greased the guide rails etc.
What is it in the electrical motor that causes it to lose power? What part would need replaced? As, I can get to the inners of the armature etc on the old motor.
Can you buy new inner parts for these from a Bosch service centre?
Thanks for replies.
If the motor works and spins when not under load, then put it back in with the glass attached, then put a voltmeter over the motor connector and see if the full 12 volts is being applied,,a motor cannot lose power, but a poor earth wire may be the reason, or is the glass to tight in the tracks, these motors do contain a thermal overload 3 sec
Stevie A
Stevie A
Scotland
Once again, thanks for replies. I'll get a pal's volt meter and try that, and have a look for a regulator without the motor. Cheers.
www.ckinsurance.co.uk
